35" tires with a 3" Suspension Lift?
RoadBoss
Travis
Lakewood, CO
www.TJAoutfitters.com
Here she is in all her glory. I will get better pictures when the snow melts. Really happy with this build! I feel like I could have pushed for 35s but the 315/70/R17 KO2s equate to 34.4" in diameter so close enough I suppose ĀÆ\_(惄)_/ĀÆ. Required a crash bar delete but that was it for now. I plan to trim the wheel well liner since there is some minor rubbing going on when the wheels are fully turned. Does anyone have suggestions for caloborating the odometer? It would be great to have my mileage calculated properly.
most manufacturer labeled 35" tires usually measure 34.5" anyway, so I wouldn't take that 34.4" into too much consideration.
but very cool they fit with so little extra work!
cam_97
cam_97
Cameron
Canada
camslupeiks.io
Ford Ranger 2019 XLT
Software Developer
Thanks! The KO2s are pretty quiet considering their size, so that's definitely a plus. Probably going to invest in some lighting upgrades and some Fox 2.0s in the near future.
qwerth
Cos
SoCal
2019 Shadow Black Super Crew
Awesome! im sure you can get 35's to fit, happen to have anymore pics?
DevilDog1775
C
C
I saw you said 3" lift. Was it a lift or a level? Curious what you did in the rear. Thanks!
cam_97
cam_97
Cameron
Canada
camslupeiks.io
Software Developer
I installed the 3" levelling kit from ReadyLIFT. I plan to upgrade to a full Eibach suspension lift next year when I have the cash. I was going to add 1" blocks in the rear but decided against it, I like the look of the truck as is and I'm not planning on doing much towing until the summer.
sirgeorgee
Geo
Austin Tx
2019 Ford Ranger XLT
i have the fox 2.0 with icon delta joint UCA- i made 285/70/17's Nitto Ridge Grapplers work well with Crash Bar Delete. Maybe the BFG K02's run slimmer than the Nitto's because theres no way i could fit a 34+ tire without serious turning issues.
Ranger 4 Play
Michael
FL
2019 Ranger Lariat FX4
Can we get more pics of this sweet machine? I want to see front tire clearance, it will help me decide on size for mine.
Thanks!
Andy
Andy
Thinking about getting a set of 35/12.5/17 or possibly 35/10.5/17.
Anyone else here running a 35ā€ tire? I have a 34ā€ tire now and I have about 3/4-1ā€ of clearance across the range when flexed out.
Ive already replaced the crash bars and the truck is at 3ā€ of lift in the front and 2ā€ in the back.
Kenda makes a 10.5ā€ wide tire that might fit nicely.
https://simpletire.com/kenda-lt35-12.50r17-601002-tires
Skyler
Skyler
Ford Ranger
Thinking about doing this to my ranger. So you just had to cut the crash bars? You said minor rubbing at full lock what about when at full articulation? I'm debating between running 35x12.5r17 or 33x12.5r17
HoosierT
Tyler
Fishers, IN
ā€˜19 Ranger Lariat FX4, '17 Explorer Sport
I’d love to know if 34s or 35s rub at full articulation. My 33s have zero rubbing in any position but I’d love to go up in size when it’s time for new tires.
Edit: Nvm, found the answer in Andy's thread. Planning to go up to 285/75-17 on the next go. 1.1" bigger without having to go down to 10.5" width.
Skyler
Skyler
Ford Ranger
So if 285/75/17 fit do you think a 305/70/17 would fit without rubbing at articulation? The 305s are about an 1ā€ wider
HoosierT
Tyler
Fishers, IN
I wish I could help but I'm going strictly off the information in another thread and it doesn't have any testing info with 305s. If I had to guess, you would have rubbing with articulation with that size tire. However, if you're wanting that wide of a tire then presumably you don't do any heavy wheeling so articulation may not be much of an issue.
