2019 Ranger lariat 4x4 hesitates
gregg
Greg
Middle Ga
Hi, I have about 80k on my ranger. Over the last year or so, I've noticed a shudder while driving. Slow speeds and high speeds. trying to figure out if its the motor misfiring or the transmission shuddering. I put an OBDII reader on to see if it was throwing any codes and it's clean. It usually happens when driving a steady speed 30-40 mph or higher. Just driving along and it will hesitate. If I downshift, it seems to help it go away. It happens just about any time really. I can be driving along steady and it will hesitate and then re-engage. Cold engine or warmed up. 2 wheel drive. Any ideas? Thanks in advance.
NotBudule
XLT
Could be the dreaded "water in spark plug wells " ? , but that usually sets a code
There is also an EGR sensor that craps out , but it also usually sets a code ...
ITS NOT THE TRANSMISSION!!! You should have 15000 left on that...
gregg
Greg
Middle Ga
Thanks I'll look at the water in spark plug wells issue. Glad its not the transmission.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
The DPFE usually doesn't set a code.
Replace it first. It is a 20 min job, tops.
The trouble is getting one. They're pretty much always out of stock.
If it isn't the DPFE valve (which would be my vote as well), I'd replace the plugs - I can't imagine going to 100k on one set of plugs - they get abused pretty hard. I replaced mine at a little over 40k.
Looking online, Tasca Parts says they have 179 in stock (if that is true):
https://www.tascaparts.com/oem-parts/ford-egr-vacuum-control-lb5z9j433b
Levittown also shows them, but doesn't say if it is in stock or not:
https://parts.levittownfordparts.com/oem-parts/ford-egr-vacuum-control-lb5z9j433b
gregg
Greg
Middle Ga
I went ahead and ordered the part. Big change in price from a few years ago and now. lol Thanks everyone for the quick answers and information. I read through the whole 42 pages of the valve replacement thread.
You guys are the best!!!
ctechbob
Shawn
Adult Daycare
Probably need a new EGR valve
part#LB5Z-9J433-B
Check this thread out
https://www.ranger5g.com/forum/threads/bucking-surging-epidemic.14581/
That's the DPFE sensor, not the EGR valve. Regardless, it is usually what causes the problem.
FWIW, the Standard Motor Products is a Motorcraft part with the logo sanded off.
https://www.ranger5g.com/forum/threads/bucking-surging-epidemic.14581/page-41#post-626725
https://www.ranger5g.com/forum/threads/bucking-surging-epidemic.14581/post-627807
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
part#LB5Z-9J433-B
That thread is how I learned to check the part referenced, an EGR differential pressure sensor, part number KA1Z-5L200-A. I purchased the sensor from my local dealer and installed it myself, using the original hoses but new band clamps, in under a half hour. That solved the problem. The selling dealer in FL steadfastly refused to troubleshoot the issue because Ford wouldn't pay the shop rate for troubleshooting and insisted the problem was in my head, the truck was operating normally. I put up with the issue for almost three years until I stumbled across that thread and fixed it myself for under $20.
gregg
Greg
Middle Ga
I ordered the complete assembly, cost more but I figured why not. Thanks
ChiefQM
Bill
Hiram, GA
It will be easier to change that way. I am a cheap SOB and only ordered the sensor.
gregg
Greg
Middle Ga
Just an update and a big thanks to all that helped solve my issue. Part came in yesterday and I installed it this morning. So far so good. Seems to have solved my issue. i replace the whole assembly. I must say it was a pain in the knuckles for sure. Took about 30 mins. For the person that recommended taking the bolt off first and then moving the sensor out of the way helped gain access to the spring clips better.
Again, thanks to all!
RangerRob
Central, OH
2024 Ranger Lariat FX4, 2014 F150 FX4
Same thing here .. 2019 Lariat that I am extremely pleased with ... the tranny has always been a little "hunty" but I believe within spec for the R10 tranny.
Lately at just over 80K miles mure of a shudder or pulse at light load or slowing down at 50 mph or so ... just replaced the LB5Z9J433B part (EGR Solenoid Valve) and will report back.
Considering plugs ... and possibly the tranny fluids.
Conman50
Conrad
2019 Ford Ranger; 2014 Ford Fusion
Water in spark plug doesn't always throw a code. Usually plug 1 fills up. Mine was all rusted up when I looked, but I never got a code.
Could also be a good idea to replace spark plugs if not already done. I hear on turbo cars you should replace between 50 to 60k.
