2.3L - 6.2 quart oil change capacity...
Hocakes
FL
'22 Ranger Tremor
I changed mine last week & had a lot of difficulty getting a reading because so much oil clings to the stick along a good stretch of the length. You can feel the stick rubbing against stuff inside as you insert it & pull it out. Any tricks??
jmkiser
jmkiser
Anchorage, Alaska
2021 Ford Ranger Lariat FX4
Data/Telecommunications
So, I ended up using a Dremel Tool with a polishing wheel and polished about three inches from the end of the stick. I usually view the backside of the hash marks, it's just easier for me to read.
REDWM
Western Colorado
2019 Ranger, 2011 F150, 77 MGB, 2023 Bronco Sport
Mine did the same thing right after I changed oil. So,let the stick sit in the engine overnight and look at it in the morning.
anix
Aaron
2020 Ford Ranger - Lariat 4x4
I was having a hard time getting a good read on mine too. I wasn't too worried about it because when i refilled I just put in 6qts flat.
I pulled the dipstick without bending it at all and was finally able to get a good read. I was just under the full mark.
For a while I did the 6.2 on my 2019. For kicks I decided to see what the dipstick looked like with just 6 in there and I didn't see a difference. From there on I stuck with 6.
