NvrFinished
That is what APG said would be required if you want longer travel out of the rear. They said the Deaver leafs only slightly increase travel over the stock springs due to how they are located directly under the frame. The Raptor stops are supplied because the leafs would actually lose upwards travel with the stock bump stops due to the thickness of the added leafs over the axle.then either relocating the springs outside of the frame with longer springs or completely linking the rear is an efficient use of one's time for max gains.
I just found out I'm going to be a Dad with my first child
Congrats by the way
