dangerranger16
- Joined
- Jul 11, 2019
- Threads
- 13
- Messages
- 94
- Reaction score
- 109
- Location
- Springfield
- Vehicle(s)
- 2019 Ford Ranger XLT FX4
Part number 401342 is for a 2.75 inch inlet outlet exhaust. My stock exhaust is a 2.5 inch od between muffler and flex pipe which is where the resonator would be mounted. Am i missing something or do we have different stock exhausts?OK, pay attention if you order. I meant to order the one I could clamp on and accidentally ordered the one that is for welding. Knucklehead move there. Anyway, I still clamped it, but had to cut notches into the pipe-ends of the resonator to allow it to compress with the clamps. See https://www.borla.com/products/universal-resonators/ Then you want part # 401338 to weld on or part number 401342 to clamp on. Put it on the pipe between the downpipe and the catback.
The second picture shows how much of the pipe I cut out. I can't remember what the measurement was, but it should be at least the length of the larger resonator section but less than the total length of the whole unit. You need some of the pipe left to clamp on or weld to.
It is a pretty quick job. It just cuts the edge off the sound a bit without sacrificing the power. I called Borla before I put this on and they said it would not affect the power and that you can put as many of those on as you want.
I started with one and it has worked for me. However, I did just install the CR Performance turbo upgrade and it is a bit louder again now. Maybe I will get another. But I'll wait a bit. Note that you want the 2.75 inch to work with the factory pipe. If you want to go with 3 inch, you will need to change the connection to the downpipe.
Let me know if you have any more questions or want a better picture.
