Whistle sound on acceleration
bigbodzy
Saskatchewan
2022 ford ranger
Farm hand
Hey all,
I've been going through this site since I found it and have liked what I see.
I purchased a 2022 ranger FX4 in October. Love the truck, and the size is great for city driving too.
Recently there has been a whistling noise coming from the engine while accelerating.
It seems to start at 1800 rpm while accelerating around 50 kph. It can also be heard when you put your foot into to pass. I have read similar threads to see it they are similar but I camt find anything similar. The sounds is not made while not moving with the hood up reving the engine.
I camt see any hoses off amd they all appear to be in good shape.
I have video attached below.
Your input would be welcomed.
bigbodzy
bigbodzy
Saskatchewan
2022 ford ranger
Farm hand
You know your truck is turbocharged, yes?
Yeah... but is that how its supposed sound? It's been getting more noticeable in the last month or so...
Never had a truck with the small turbo on it
RangerBill
Maybe an air leak in the intake piping. Check clamps and fittings for tightness.
bigbodzy
bigbodzy
Saskatchewan
2022 ford ranger
Farm hand
Wiill do thanks
From your written description, regular turbo noise was the first thing I thought of. After playing the clips, I was thinking how it sounds like my truck when the turbo is spooling up. A smooth whistle that increases and decreases with throttle.
Turbo noise on these trucks is relatively faint but noticeable, especially with an aftermarket CAI or if you don’t have the foam engine cover. If it was happening at idle or was very loud and sharp, I’d have it checked.
Off topic note: When looking at the scenery in your first video, I had a hunch, looked over at your profile details, and it was confirmed. Nowhere else looks quite like Saskatchewan . 👍
bigbodzy
bigbodzy
Saskatchewan
2022 ford ranger
Farm hand
Ok thanks fir the reply and yeah you got a pretty good eye!
One time, I was driving my rental out of the Regina airport to a reservoir (Buffalo Pound maybe?) and I swear I could see the Calgary Tower on the horizon. :wink:
TerryW
Terry
mineral, va
2023 Ford Ranger XLT
You should not be hearing a turbo whistle on a stock system. If you do, you have clamp that is not seated properly between the pressure side of the turbo and the throttle body. The clamps may all be tightened, but if not on the hoses correctly they may leak just enough to let a bit of pressurized air to whistle out. Same thing happens on aftermarket pipes too ...[/QUOTE]
Roscoe_t
Russ
2021 Ranger XL Supercab
[/QUOTE]
I get a slight whistle when I'm backing off the throttle after accelerating to my preferred speed. The turbo's wastegate actuator has been known to have problems, which Ford seems to pronounce as total turbo failure.
Not that that's what's happening with your truck -- but it has been reported by others. Ford replaced my turbo under warranty.
