What is wrong with this Battery???
Hi Folks,
I had an experience today on my Diesel Pusher RV before which I have never experienced.. I check the RV frequently for electrical health via several monitors and there have always been Green Lights for normal system functionality. So decided to pull it out and give it a sponge bath today. It would not start...It has two Group 31S batteries. So I accessed the engine start batteries to see what might be going on with these batteries... As far as I could tell, things were just fine..
Here is a picture of one of the batteries as I removed both in my investigation of a no start condition of the CAT Diesel...
Any folks see where the problem might be??????
Baffled in Green Valley (not!),
Looks good to me. It just needs to be put on a battery maintainer for a few days. ?
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Wow. Is that a cutaway battery? :shock:
Looks like you'll be putting the Ranger to use getting a couple new batteries.
Hi KJ,
Yep...Ranger chased to O'Riley AutoParts as they had 4 31S in stock...$400... Not too bad to install except for the weigh lifting into the compartment and cleaning up the mess from the shorted battery ....
Fired up the coach and it purred just fine...all is well again....so now I do not trust the battery health monitors at all. I have never had a battery do this before... Gotta be an internal short and thank goodness it did not cause a fire.... I think I will replace these new batteries in short order next year with good quality AGM batteries.
Did the battery compartment door have a damper installed?!
HI Sammy,
This is the one door on the coach that does not have gas struts... ... Too small a compartment...In fact so tight fit that my hands almost were too big to get to the hold down system..
Sammy
Tenn
2024 Lariat FX4, 2019 Ranger... traded.
HI Sammy,
Guess we need Dave to do some research into finding the correct damper to remedy this dire situation!
Blue Streak
Larry
Hi Folks,
Nothing a little Red Green duct tape won't fix. :like:
Figarou
Hi Folks,
Overcharging
https://itstillruns.com/happens-overcharge-car-battery-5137116.html
Overcharging a Car Battery
While a few variables may be involved with overcharging a car battery, the results are simple to check. A battery can quite simply die from being overcharged. This is the safest side-effect, but not the only thing that can happen. An overcharged battery will boil the sulfuric acid and distilled water mix. The casing of the battery can become hot to the touch, and begin to melt or swell. Flammable hydrogen can build up inside the sealed cells of the battery, causing swelling of the casing under pressure and seepage through small vents. Once the hydrogen is introduced to oxygen, it becomes a sitting time bomb. A small electrical spark can ignite the gas and cause the battery to explode, sending plastic and lead shrapnel flying around, in addition to a caustic sulfuric acid spray. Obviously, this is the most dangerous side-effect of an overcharged battery.
