- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,473
- Reaction score
- 8,545
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
- Thread starter
- #1
In digging deeper into the noises, the truck makes (Wake-Up) , what I though was the HP Fuel Pump priming is actually the Wastegate Actuator cycling.
On the Wake-Up subject, I did confirm that the periodic wake-up, if standing near truck that some have experienced, it is not the FOB, as I only had my phone on me when it did it, so I have eliminated 1/3 of the possibilities.
1. FOB - Eliminated
2. Phone (Ford Pass - Proximity near truck) as if you are near truck long enough it will repeat a number of times.
3. Phone (Ford Pass - Itself) looking for update on health, tire psi etc - (Not dependent on proximity)
I am highly curious if it does it when the truck is all alone, need camera to monitor - as sometimes I note the parking lights flash along with the uncommented wake-up.
If you have not experienced this little quirk, while working around truck, and the truck comes alive (wakes up) without anyone touching the door handles etc
Now I know that the PCM wake up occurs when opening the driver's door, ignition key or switch cycled, and remote start.
Now the specific question:
I can understand the reason for the HP Fuel Pump (Prime)
But why specifically does the Wastegate Actuator, Cycle?
The only thing I can conclude it does it for the purpose of ensuring. correct position for engine start and also ensures it is not stuck open.
Plus, this cycle will ensure that the wastegate is actuated full cycle (open and closed) as a preventive measure to help prevent sticking.
As far as the noise it makes, since I never paid much attention to it as I always believed it was the fuel pump, now notice the difference between the 2, the HP fuel pump is noisy just after start and then settles down along with the cooling fan.
I believe the (R2D2) sound as some have described it, is the Wastegate Actuator, I confirmed with a Mechanics Stethoscope.
Since I do not have a comparison truck to compare the noise with, is this noise common for all Rangers
Note: The noise can be generated just by opening the driver's door.
Since the manuals and online search does not cover this specific action, I am seeking input from others with Turbo knowledge.
Am I correct on my conclusion?
1. FOB - Eliminated
