Transmission Horror Story (replacement/factory underfilled?)
Dgc333
21 Ranger Lariat
Dgc333,
Did topping off the trans seem to have any benefit now that you’ve hopefully had a chance to drive a bit?
Well we haven't been having temps below 30F to know for sure if the additional fluid corrected the weird shifting when cold. Above 30F it has always been fine.
Chattownranger
Chattanooga
2020 Ranger
Mechanic
Gotcha. Well hopefully that did the trick!
Mike C.
Illinois
2020 ranger
Education
I just checked my transmission fluid level. It was not showing on the dipstick when cold. It took a 1/2 quart to bring it up to the cold level. It seemed to perform a little smoother on the cold shifts. I did need to pull out 100ML out on the last check. The fluid was a dark red at 15K. Will need to think about a fluid change at 30K for my own piece of mind
BrassSlinger
Rich
Western North Carolina
2022 Velocity Blue Tremor Lariat,2017 Honda Civic
Technician
Talked to my dealer yesterday. Having them check my trans level as soon as my truck gets delivered. Said no cost to me
NotBudule
XLT
I took mine to dealer yesterday (1200 miles) and asked about checking the fluid as I herd some may be low from factory and we talked about the rough stuff and then we both just kinda shrugged it off till oil change... I may check it myself anyway ... Swore I wouldn't though,
Bob902
St. Louis
RETIRED!!!!
Just checked mine. Was ok. FYI. A Gearwrench makes removing the plug really easy.
Bob902
St. Louis
RETIRED!!!!
Nope. I loosened it up a bit first. Wore Mechanix gloves and a long sleeve shirt.
Bsqrd
Arizona
2020 Ford Ranger SuperCrew Lariat FX4
Just took my truck to the dealer for routine oil change and asked if they would check my Trans fluid level. After some waiting I was told that they can't check the level in the QuickLane service line. I would have to make a special appointment with a Transmission Tech to check the level and he is booked two weeks out. So let me get this straight, not only can an owner not check the level, now no Ford tech can check the level unless they are a "Transmission Tech". Who was the idiot that Ok'ed this design? (Personal Rant) I was so angry I told them to forget the whole service. Now I'm going to have to spend the +$200 for the Dipstick kit. :curse:
Matsterious
Matt
Houston, TX
2022 Ford Bronco Big Bend 2.7L Mid Package 4.27
I think I would prefer not having the quick lane guys touch my truck- i don't trust them with an oil change let alone my trans!
But on that note- it shouldn't be this difficult to check the fluid level- not a good design at all!
Tyler
British Columbia
2020 Ford Ranger XLT FX4
Corrections Officer
alright, so I got my truck back a week ago after having the whole transmission swapped. Me now being paranoid about the transmission, although currently shifting smoothly, went out and bought a long extension and a ujoint adapter so I can remove the dip stick cap from the engine compartment. Slid under the truck to check the cold level. See photo below. Now from what I’ve seen on this forum this must be overfilled. Cold truck and 11 degrees Celsius outside. Now how do I go about a removing some fluid without dropping the transmission pan? Will this excess of fluid cause damage? Help.
Dgc333
21 Ranger Lariat
Well we had a few cold days in the 20s last week and the funkiness when cold appears to be gone.
Dgc333
21 Ranger Lariat
Something doesn't look right in your photos. Why is there no fluid on the dip stick below the diamond between 5 and 4? It looks like you dragged it across the edge of the fill port taking it out and picked up some fluid on the middle of the stick.
You are also supposed to cycle the tranny through reverse, neutral and drive for about 10 secs each before putting it back in park for the check.
Augie81
I'm due for an oil change next month paid for by reward points. When I call to schedule it I'm going to request a transmission fluid check just for the heck of it. If I have to pay for it and wait longer no big deal. Better safe than sorry.
Tyler
British Columbia
Corrections Officer
There’s no fluid below because I grabbed the bottom of the stick with the towel before readjusting to take the photo. No fluid drag. And you cycle the tranny for a cold check? Good to know.
