10r80 Transmission factory re-flash and VB repair
TheRealStreetcommander
Juvenile
VA
2020 Ranger FX STX FX4
None of your business
Update,
I traded the truck in on a Jeep Gladiator. The HVAC blend door problem reintroduced itself after about 6 months and I simply had enough. Actuator and eccentric popped off the blend door lever, even though the actuator was still affixed tightly.
Even broken, it held its resale value very well —thanks Ford, or Wuhan Lab, or federal reserve inflation, …or whatever reason.
Mopar’s have been exceedingly reliable for me and my family over the past 25 years.
For all of you who have a good Ranger, I wish you continued joy and happiness. The truck is the best mid-size truck by any objective standards. Mine was simply an aberration.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Sometimes a vehicle can go from the best dog you ever had, to the mutt you can't stand.
At which point the expression "nothing gets over a old dog like a new puppy" comes in, I have applied that to dogs, cars, motorcycles even women.
Have fun with the new puppy:like:
ebob9
A
Fremont, CA
2021 Ranger Lariat Supercab
Professional Lurker
Was there a service bulletin # associated with that repair ?
I am guessing this is the TSB (or at least the most current version) - TSB 22-2428
Note, this TSB has been updated a ton and changed monthly since around April. The fix is MUCH more involved as of the May 2023 update!
For comparison, here is the superseded TSB from April 2023 - TSB 23-2123
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
It sounds like the dealers were a little in the dark and guessing at how to resolve the transmission issues - replacing the PCM sounded like a desperate try.
I haven't had any major issues with my 2019 (pre CDF drum update) but occasional inconsistent behavior. I wonder if not everything is due to the tranny but maybe engine sensors too.
The software update from Ford as well as certain tuners being able to influence shifting - and the former can be in conflict with the latter without returning the factory tune to stock first - but it just sounds to me Ford is hiding an update to the valve body that affects performance. Not simply some 'gasket' replacement.
It really affects someone out of warranty willing to put their own money into 'fixing' the transmission vs. those with warranties and patience to work through the dealership.
No mentions of transmission fluid levels.
As for the blend door failing twice, that would torque me off, warranty or not.
myothercarizahearse
Cleveland, Ohio
Unretired
Update,
sad but you have to do what you have to do. are you sharing any pics with us? any mods planned?
Michael7571
Michael
New York
2022 Ford Ranger XLT Splash Edition
Genuine improvement.
I took my 2020 XL STX FX4 CC to Ford at 59k to have the trans reviewed before warranty expired.
I noted harsh shifting as my concern. Dealer said the valve body needed to be replaced, however the warranty receipt only shows “rebuilt” with new gaskets, seals and (2) separator plates. Additionally, they performed a re-flash.
Pleased to report a 100% improvement. Better than new. My assumption is that the biggest improvements are the result of the trans reflash. Shifts completely different now. New thing —Tends to shift 1-2 and then skip shifts to 4 under moderate accel. Used to be nearly permanent 1-3 skip shift. Still does that but only on light accel. Also holds gears longer and does not PWM/hyper flare the converter nearly as much. So much better and more refined experience.
I highly recommend people ask their dealer to perform the same service. It’s so much better, I’d even pay for it if I had known how much better it is, and I had been out of warranty.
I tried this last week and does just what you said about shifting differently and holding the gears longer. Feels like it’s in sports mode. Amazing difference.
Spazzz96
Jordan
USA
2023 Ford ranger XTL
Hey there. So i have a 23 rangler xlt 2wd with 21k miles. When I bought it the transmission was a little rough. Lugging at certain times and just not always smooth, but I read it was normal so didnt think much of it. Over a few months the transmission issues were getting worse. I finally had the time off to take it in and leave it for a few days. It was lugging in slow speeds in residential areas, when going up hill and random times for some reason it just wanted a higher gear than it probably should have been in and hard shifting when cold.
Luckily they gave me a rental for free after 5 days.
Ford did a transmission reset and new valve body. I just got it back after a month in the dealership and have put 150 miles on it so far. The transmission is soooo much smoother now. Better than when I bought it new. I dont even notice it changing gears now. The paperwork stated a solenoid had some scoring and a couple of them failed a "gravity test" (whatever thay is). I know its still in the learning phase but i hope it stays this way. Its way better. I wonder if it also had low transmission fluid from the factory also.
thats good news! i hope it stays that way for you.
