Trailer Tow Package
Robert Manikowski
2007 F-150 Lariat
I will ask my dealer when I talk to them, but do dealership have the ability to add the trailer tow package to a in-stock vehicle if it isn't equipped already?
There is a ranger they have in stock and it is really only missing the trailer tow package.
rangerdanger
SF Bay Area
Yes, I saw that - I guess I don't mind having to wait but I also wanted it factory installed as opposed to me installing a 3rd party hitch.
You can install the factory hitch, I don't believe that's delayed, only the wiring harnesses.
Live4FW
Scot
2019 Ranger XLT Screw with a DAMPER!
I installed my hitch. Pretty easy. I got the Curt Class III. Clamp the bumper to the frame (suggest using vice grips) remove 4 bolts and replace bolts when putting hitch on.
I have searched for a plug and play 7 pin harness and they just don't exist yet. You can get a harness that plugs into your 4 pin connector and then manually wire the other 3 wires. I am only going to need 4pin connections for now so I am just going to wait for the market to catch up.
Neil S
Neil
TN
2019 Ranger Lariat FX
Harness and 7/4 pin receptacle: (yes both are available)
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Thanks so much for posting the part numbers. My local dealer wasn't sure until i gave the numbers to him, but now i have the parts coming. Thanks again.
rang19ca
Chuck
Carpinteria Ca
OK, i received the parts yesterday. My dealer thanked me for the numbers and he was able to help another customer looking for the same thing. Once again, Thank you.
Traneman
Jay
Rochester MN
2019 Ford Ranger STX 4x4
Do you know if the trailer tow package has a transmission cooler for the transmission?
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
There is a transmission oil cooler but not sure it is specific to the trailer tow package.
VAMike
2019 Ranger Lariat SuperCab
There's nothing in the package but the receiver and 7 pin connector. The wires are there either way, so adding the connector is easy if you don't get the tow package, and third party receivers are pretty cheap. That said, the tow package is pretty cheap for oem, so I'd just get it for simplicity--but I know a lot of dealer orders didn't spec it, so don't sweat it if you're looking at a truck that's otherwise perfect because adding the missing bits isn't that big a deal.
edit to add: apparently some trucks (XLs only?) do not have all the wiring for the brake controller. your mileage may vary.
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
There is an oil/water heat exchanger (transmission cooler) off the drivers side of the transmission. Should be on every truck as far as I can tell.
Dusting_for_vomit
Alex
Salt Lake City
Did you encounter any issues with the spare getting in the way of the install? I noticed the instructions say that it isnt necessary to lower the spare first (not sure why this would be needed), but mine would not get into position with the spare in place
