TPMS inaccuracy
Sounds like you might have a faulty tire pressure gauge to me. That said a failed TPMS usually throws a code or shows a ridiculous pressure.
Rinn69
N. Central Iowa
Retired USAF MSgt
Mine is only 1 pound different than my dash gauge. My MPG is within 1 mpg as well after several tanks of gas/adjustment.
@Tim H.
2 questions:
1--Are you running factory size wheels/tires ?
2--What number did you "plug in" to get that close for mpg ?
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
Mine is dead nuts on target. Just slow to read and respond.
Cabose-1
Eli
Student
My tpms is pretty accurate. 1 off what any of my guages say. And i have 1 sensor that is always 2psi off. Weird.
If they are off, try resetting the BCM and RTM (Using Forscan and performing a Self-Test - the TPMS sensors transmit to the RTM and the RTM sends the info to the BCM.
This will reset the TPMS system as far as communication goes in transmitting the pressure data.
You can recalibrate them but this requires a high-end scan tool with the TPMS function, I'm not sure if Forscan can do it as I have it on my Autel scanner and honestly have only used it once the whole time i have owned it for the TPMS sensor calibration.
I plan on using it for the Ranger when tire rotation is due (Soon) as the truck won't recognize automatically where the tire is moved (Location). I don't know if tire shops do the relearn.
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
I can tell you that both of my Fords (2020 Ranger and 2018 Fusion) absolutely learn the location of the TPMS sensors after rotating tires.
Colo_Ranger
If you live by a Discount Tire, they have a tool that will reset the sensors. I had them set the pressure to 35 psi and then reset the sensors. Now it matches exactly. I know their autoflater is quite accurate on pressure reads. Now my sensors read 35 after being filled. I had one that read 15 psi off before I had DTC recalibrate them.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
Thank you for the shout out! I'm happy to hear that your tpms sensors and air pressures are back in line.
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
We do have one near us, may give it a try. I found some tutorials for recalibrating the TPMS at home too. Instructions seem to vary, but there is one that says to deflate each tire one at a time while waiting for the horn to honk (I guess this tells the system where roughly 0 or some low psi is)? I do have a bunch of jack stands so I could guess I could do this without damaging any of the tires. Will read up on it a bit more before trying, or may just head to the tire shop. Thanks for the tip!
Colo_Ranger
You won’t hurt the tires running them to empty with the weight of the truck, just don’t drive on them (duh!) and you’ll be fine. Discount takes about 3 minutes to do, so it’s much less of a hassle, imo.
