This can’t be good. Ugh!!
landiscarrier
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Now the question is. How did you spill that oil without noticing?
HA! I'm 52 years old and have been changing the oil in my vehicles since forever! I'm always pretty careful about it....my best guess is "shit happens"!
Floyd
illinois
For the most part it seemed to be running good…..just seemed a little off so I thought I’d change the plus. 35k on the motor. And I definitely do not beat on it.
Look at it close or have it looked at immediately, your base warranty is about to expire!
Floyd
illinois
On most of these new cars it ain't hard.
I always poke a hole in a rag and put the funnel through the hole, then wrap the rag around the base of the funnel when installed.
CB750F
Qc
Human
I'm going with this. "Shit happens!"
landiscarrier
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
My only question is …. If I did spill oil when filling how did it get past the rubber seal on the coil pack? ??
rcairflr
Kansas
2020 Ford Ranger XLT 4x4
I have seen it many times on different engines, it's usually the valve cover gasket.
You could very well be correct, but that oil looked perfectly new. The Op did not state when he last changed his oil
landiscarrier
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Oil was changed about 3000 miles ago. I change it every 5k. I’m thinking it’s spillage but how would it get past the rubber boot on the coil pack? And only in the center 2 plus not the front ans back.
That being said….the truck is running fine. And not smoking at all. I did make an appointment at the dealer to have it looked and documented.
Langwilliams
Langley
Lorain, Ohio
eventually it will seep in. Kinda like when a bolt is rusted in place. You spray it an eventually it seeps into the threads even thought it's tight an covered in a layer of rust.
I think there's a TSB on water seeping past the coil packs an shorting or fouling out the plugs under certain conditions.
FoD
Terry
Out There
Retired & Grandparenting 🤣
in true Ranger5G fashion, there's one of two solutions to this problem
if you have a TG damper, remove it. Its the cause of your oil issue.
if you don't have a TG Damper, install one, It will fix you oil issue.
As with most wrong internutz information, the damper doesn't use oil, just 303 nano nantucket graphene carbide particulate. The newer SYNC uses it.
But, when using a rotisserie to change oil out the spark plug holes...
