Think I Threw a Rod....
OFC Ranger
Jack
ZR2
It's not really a defeatist attitude but a realist one. Who's wanting to spend thousands more than the repairs are worth on lawyers fees and having your truck potentially tied up for years? Not trying to be argumentative but at some point you have to cut your losses and get on with it. As far as small claims court goes I would think the repairs would be over the amount they allow there?
I do not disagree however a response from the company that “the mods” did it without specifics is definitely not going to be that line in the sand. not even close.
I think small claims varies by state in GA its either 5k or 10k
TBR17
Murphy North Carolina
0-60 mid 6 second range & mid 15s quarter mile in a bone stock 4wd 4 cyl pickup that can tow 7500lbs, go almost anywhere off road that a Jeep can and get over 20mpg. This thread reminds me why in my older age I buy a vehicle for what it is capable of from the factory. Just don't need the headache. Truck is comfortable, drives nice and tows the boat flawlessly. If I want to haul ass then I fire up the Vette which is also bone stock only slightly faster and has no roof when on the road. :sunglasses:
dtech
colorado
paid for by??
the sad part about legal proceedings, is the lawyers likely know from day 1 who will be the winner of the battle.
In this case agree 100%, so steep an uphill climb that even a GOAT Bronco couldn't manage to make it to the top.
People get locked into their positions and often times are willing to pursue trying to pull a rabbit out of a hat and some astute lawyers will take advantage of that and yes that's how they make their money, billing you for everything possible.
Find a decent honest lawyer (they do exist) and I believe they would advise the OP not to pursue this case with Ford, unless they have deep pockets and willing to win at any cost, be it far in excess of just replacing the engine and moving on.
VAMike
2019 Ranger Lariat SuperCab
I guess I just dont get the defeatist attitude. Worse case take them to small claims court dont need a lawyer for that.
Some of us might just think it's stupid to waste the court's time with something that's ridiculous. Armchair lawyers who want to tune are convinced that the magnuson-moss act gives them coverage for anything they feel like doing to their vehicle, but it just doesn't. It's easy to cherry pick bits and pieces that support the idea, and ignore other bits and pieces and precedents. Sure, the act says that the manufacturer can't void a warranty for third party parts. More specifically, it can't require branded parts, but it can require parts to meet certain requirements. (Must operate at certain voltage, maintain certain pressure, etc. It's hard to argue successfully that something specifically intended to run the engine at levels outside the manufacturer spec complies with the manufacturer spec.) It also says that the manufacturer can add exclusions and limitations (like, "don't modify the engine") and also specifically excludes "unreasonable use". If Ford sells an engine that's designed to operate within certain parameters and you decide you want to operate it under different parameters even though Ford said they wouldn't cover that and it breaks, that's reasonable? People are also overestimating the burden of proof the manufacturer needs to show here--you'd better have a counterargument about why an engine pushed beyond its intended operational limits blew up that's more credible than "I don't want to believe that my modifications had an effect".
Maybe you'll believe someone who sells tunes? https://www.stage3motorsports.com/Stage-3s-Stance-Tuning-Your-Vehicles-Warranty.html
Hi, my name is Debbie Downer....
isnt this where the tuners say it was caused by a failed oil pump, and its not their warranty problem
Ford holds strong on "not an oil pump failure, failed because of the tune"
and the OP pulls out his hair in frustration, burns the truck to the ground. and buys that sweet new Nissan? lookit those body lines....she's sweet
Yeah, I sure love that new Tacoloradatier 150!
OFC Ranger
Jack
ZR2
Again, a response of "because of the mods" doesn't even come close to the threshold where I pack up my bags and call it a day. I don't care if it was the tune or not.
outdoorphotog
Ian
Healdsburg, CA
2019 Lincoln Navigator L
Limo Driver
I am pretty sure Ford doesnt have to prove the tune caused the damage, since installing the tune itself is what invalidates the warranty, which occured prior to the damage.
Vitis805
Santa Barbara County, CA
2019 Ranger XL
Wine Nerd
I'm with this line of thinking. Maybe it's just my curiosity, but I would like a pin-point on the parameters that caused the hole in the block. "Failure due to _____ being subjected to _____ from the increased (or decreased) ____" or similar. You get the jist. Maybe Ford did and OP just isn't revealing that (not that that's an accusation). It's just part of the brainstorm.
It's unfortunate that this happened, but I can kind of see Ford's point of view on this case. Exhaust was completely changed to aftermarket, intake was completely changed to aftermarket, charge pipes were completely changed to aftermarket, and the very parameters keeping them in order (tune) was aftermarket. Maybe if one or a couple of these steps weren't taken OP would have a better chance, I don't know. I am thankful for OP for teaching me a lesson on how far I can safely go with this truck. I am going to be able to resist the mod urge a lot better now. I hope your Ranger comes back stronger than ever, OP. Best of luck.
Leftcoast
2019 Ford Ranger Crewcab
Old outdated info perhaps.
" A few years back, Ford issued a TSB (Technical Service Bulletin) regarding blown head gaskets on 6.0 Powerstroke turbo diesel engines in F-Series pickups (2005 and up). A lot of pickups were coming into shops across the country with blown head gaskets. The common thread? Power chips were installed to boost engine output. According to the Ford TSB, on trucks with blown head gaskets techs were to check for the installation of a power chip, which increases engine power by modifying the drivability and engine management parameters. Part of the programming modification on these vehicles included increasing turbo boost (which increased combustion chamber pressures), thus blowing head gaskets. In such cases where the vehicle was under warranty, claims were denied and engine warranties were voided; the carmaker simply confirmed that head gasket failure was indeed due to installation of the power chips. The carmaker was (again) well within its right to deny claims and void engine warranties. "
A quick search found this 2020 Autoblog quote.
VAMike
You're overestimating how much effort Ford has to put into this.
