MarkCl
That construction will never last. It's similar to the axial encoders in the jet computers I used to work on during the Vietnam conflict. The military spent around $800 on some of those and they had tracks made of gold, and they still would go bad. Guys would make cufflinks out of those that were trashed.Well... I have the same issue going on now. Hot on the drivers side and adjustable on the passengers side. I've located the blend door actuator for the drivers side and it does move when changing between LO and HI temp settings but the temperature does not. I can hear a mild change in air "sound" when the motor moves but no change in temp. Really not looking forward to the idea of having the dealer rip apart my dash only to make it never go back the same.
Im going to dig through FORscan and see if there is a relearn option for the HVAC system or similar.
Edit: looks like a common problem with the actuator but mine will move to both end points and still not change temp.
