Seam Sealer Missing On Doors
joeb427
"Finessing" at 4:36.
Seems many Rangers aren't 'finessed' properly.
hughesjv
Aurora, CO
2019 Ford Ranger Lariat FX4
I just checked and I have seam sealer on my 2/19 build.
I have been trying to figure out what it should look like with seam sealer but I am not getting it. Can you explain?
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Mine has the sealer: Build date 04/17/19.
MarcusRanger
Marcus
Ontario
2019 Ford Ranger XLT, 1964.5 Ford Mustang Coupe
Thank you for doing that...I thought maybe that w
Build date 2/2019 and it has the seam seal. Do you think it has anything to do what part of the country you are in or maybe where it was built?
I'm in Ontario, Canada and we get lots of road salt hitting our vehicles. If this were true I would think mine would have sealer and it doesn't. I think what others have said is true, there was a problem with the sealer and they pushed ahead with production anyway.
hughesjv
Aurora, CO
Makes sense but it just seemed odd that some in February have it while others do not...have you asked the dealer about fixing yours?
Beef_Stew
Beef_Stew
Aaron
USA
my opinion, is that all the other process' that get done during manufacture, is this really the mountain of a problem some believe or is it just a cosmetic molehill? its only 1 part of many process'. I believe the dip in that tank is a far bigger protector for rust on the doors than some sealer over a joint.
You could look at it that way. But why should I have less corrosion protection than the next one?
dguffin
Dana
Aberdeen, SD
20 Corsair, 19 Ranger, 12 Boss, 08 Zuma
Shop Foreman
I finally checked mine after all this talk. I have seam sealer on all 4 doors, just not in the corners. I would think it should be all the way around to be effective.
FULLSCALE
Adam
Ontario, Canada
Checked mine today and I have it on all four doors except the corners, July build. I don’t think I’d be too concerned if mine didn’t have it, I’ve had other vehicles without and it never caused any issues that I’m aware of.
fordman89
Greg
Cleveland, Ohio
2019 Ford Ranger Lariat SuperCab, 2014 Ford Mustang GT
I have it on all my doors. 3/19 build SuperCab.
Jon Bokowy
Illinois
2019 black ranger
Dealer says Ford wants more pictures ,going to go back again .....I didn't pay less for my truck not to have it and those that do have it didn't pay more for it... they should all have it or not have it that simple
David Schuster
NW Indiana
2019 Ranger XLT Sport 4x4; 1969 Torino GT
My 3/12 build has on all 4 doors. Drivers rear is a bit sloppy
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Mine, built 04/06/19 has it on all four. I wouldn't be overly concerned if it didn't. There is normally sealer applied on the parts before the door is hemmed. ( That's when the outer skin is wrapped around the Inner). So the joint is sealed from the inside. There are also sealer daubs applied near the lower skin that melts in the paint oven and runs down to seal the lower seam. After all, the lower edge is the most likely to rust.
