Rock Sliders
Methos
'20 Ranger XLT
Are the ARB ones actually rock sliders? And do you know if they were bolt on or required drilling?
Lawdawg
Ryan
2021 Ranger Tremor
I installed my Rocky Road Supersliders. It would be easier if you had someone to help you but I was able to do it by myself.
I’m having a hell of a time with these! Had to go buy a right angle drill and grind down the bits to even be able to drill the holes. Not much room between the body and the frame. The self-tapping bolts are kicking my butt…..not having much luck with them.
JetEngr19
Oklahoma City
2019 Ford Ranger, 2016 Jeep Wranger
I used a step drill bit with a right angle drill. They key is to to run the drill slowly. If you drill too fast you will heat up the frame and make it harder. Some drill oil will help keep it cool also. I didn’t have any so I resorted to spraying with WD40. Same with the screws, go slow.
Lawdawg
Ryan
2021 Ranger Tremor
Thanks for the advice! I’m going to give it another try but about ready to give up. My neighbors have learned some new words and expressions the last couple evenings! Lol
azdriver
Arizona
2021 Ford Ranger Lariat FX4
System Administrator I
Anyone know if Shrockworks has solved the problem with their sliders on the drivers side not having enough clearence in the front on the drivers side?
I think I like the Rocky Road sliders more but the installation seems to be a little bit of a pain. Having to drill 24 holes into the frame doesn't sound fun at all. At least the Shrockworks sliders use existing holes. It's too bad they decided to go that route.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Somethings to consider is having 24 points to hold onto gives more foundational support and less weird leverage points to move the rock slider in weird ways.
Mustang2Ranger
Garrett
Southern California
Check out White Knuckle Rock Sliders
VAMike
2019 Ranger Lariat SuperCab
something else to consider is how much destructive testing they did after drilling 24 holes in the frame. modern vehicles aren't built with a lot of extra material.
Maltese
Adam
Oakland
WRX & XLT Ranger
Shrockworks took care of me a while ago, stated they updated their jig and the new setup fits well
dondonbabyraptor
Brandon
San Diego
Good point.
