- First Name
- Steve
- Joined
- Jul 1, 2021
- Threads
- 84
- Messages
- 5,901
- Reaction score
- 29,403
- Location
- Fishersville, Va.
- Vehicle(s)
- Previous 2021 Ranger, Now 2019 Ford Expedition
- Occupation
- Navy Vet., Retired Police Sgt., Grumpy Old Senior Citizen
OK, guess I'm the first to "mod" the stick.Final got to go for an extended drive yesterday to get my transmission up to temp. Using my phone and Torque Pro, the highest I got on the highway was a stable 190 degrees. After I pulled off the highway it went up to 195 by the time I got to my driveway. It was 77 degrees out so I quess even with the stock pan there is some cooling do to air flow.
Anyway, checked the level. It's really tough to get a good read with the hot fluid being so thin. Best I can tell is I'm right about the 5 mark. So it looks like I could add a little to get it to the diamond between 4 and 5. Not as low as some but borderline.
Has anyone come up with a trick to get the level easier to read on the stick?
I had some 400 grit fine paper and scuffed THE BACK side of the stick reading area...side with the cross hatch....NOT the side with the numerical markings. Just scuffed the area equivalent to the number markings. Left the number marking side alone as I believe Mike printed the ### on that side and didn't want to risk sanding them off.
Made it easier to read the level and seems to "hold" the fluid better.
Just scuffed it enough to remove the "shiny" from the stick tip.
