TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,953
- Reaction score
- 9,930
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
I successfully installed the dipstick today. But had a few detours to work around. I removed the stock dipstick cap from the top using a 2' breaker bar, it freed up without incident. The truck has been sitting for a week so fluid levels had settled. Pulled the Ford dipstick out and trannie fluid was at the top of the scale. Once installed , the MBS dipstick read exactly the same! Great engineering Fitz!
The Detour
My Bendpak 2 post lift is going on 20 years old, and today I noticed a small puddle of hydraulic fluid on the garage floor near both posts when I raised the truck the second time!
The truck was already up 2' and I let it settle onto the safety supports taking the pressure off the lines a few days ago. I ended up raising/lowering the truck several times during the test fitting the tube phase. The last time I actually got a slight spray and knew I was at my limit. Ended up using a floor jack to raise the truck the last time to tighten up the tube fitting. I'll be removing and replacing all the hydraulic hoses on the lift this week. I still have a PPE pan to install.
Back to the Dipstick Install
Proceeded installing the adapter to the transmission and lowered the truck to install the tube. Geez I hate working on tall trucks. I need a folding step just to reach the firewall! Yes, I am short at 5'8". Took me 2 or 3 tries to feed the tube down correctly - it is a tight fit and it only goes in one way! Follow the instructions!
I had encountered the same problem with the wiring loom as airline tech. The sensor cable looks to be positioned just as his is. My truck is a 2020 XLT Edge 4x4. I had just enough play to keep the wire loom from touching the bracket, but it is close. I will most likely move the main loom slightly closer to set my mind at ease. The AC line is far enough away to not be a problem.
All in all I'm a happy camper!
Thank you Fitz for providing this fine product.
- T
The Detour
- T
