puckdodger
Thanks Dave. I found this in the service manual and it pretty much describes my truck:Jim can you have someone drive your truck slow (maybe in a parking lot) and you could walk beside it to see if you can hear where it's coming from? At least you might be able to pin point the area and get it back home and look from there.
Scraping noise – a continuous low pitched noise starting at low speed l Worn or damaged pinion bearings l INSPECT and INSTALL new pinion bearings as necessary. REFER to: Drive Pinion Front Bearing (205-02 Rear Drive Axle/Differential - Vehicles With: Dana M220, Removal and Installation).
I hope the level kit isn't the culprit?
