Ranger Tiedowns
Status
Not open for further replies.
Hi Folks,
Well this is embarrassing, but I had previously stated with a build date of 1/22, I had only 4 tiedowns. I do have six..somehow I overlooked them as they were very heavily coated with the spray in liner. The center ones are there, so my mistake...Sorry!
best,
Ford Motor Co. Retired.
t4thfavor
Chance
IMO, 6 tie downs is at least a consolation prize for not having stake pockets like every truck from the last 50 years... I thought they would just be blanked off, and I could just pop them out if I needed to use them, but upon further inspection, they just aren't there in any usable fashion.
Maybe the bean counters did a study which concluded that only 1 in 10 would ever tie anything down in their new truck, and decided to remove them for cost savings...
Maybe we can start a 300+ post thread for aftermarket tie down options? Maybe the aftermarket will come up with something good before Christmas.
My build is pretty early, (think 2018) and I have all 6 as well. I've even used them all at the same time when I was transporting a gigantic BBQ which extended past the tailgate and was taller than the cab.
hamiltop
Peter
Danville, CA
2019 Ranger Lariat 4x2
Can anyone tell me what kind of machine screws they use? I'm trying with the idea of making my own hooks since mine only came with 4.
Caliope
Lisa
IL
2019 Ranger CC 4WD Lariat, 2022 Bronco Sport OB
They are M8-1.25
Fawnbuster
Indiana
Retired 34 years as LEO
I had a long piece of leftover ratchet strap, so I cut it into 6 equal lengths and tied a knot in each then I ran the loop thru the tie downs and back thru each loop. Did it so the knot is on the oem tie-down. This way I can find it easier in the dark or with a large load and hook a strap to the loop. One times when I had to remove an item and re tighten a strap I ran the loop thru the hole on the hook of the ratchet strap then over the hook. Then all that needs messed with is s in your hands at the ratchet.
da808moto
Wi
Rancho Cucamonga, CA
2019 Ranger Supercab XLT
Purchased my XLT SuperCab last week, I only have 4 tie down hooks, missing the center one. Is only $9 each I don't really mind paying, I was kinda MAD when i found out they are in back order, Hope I can get some compensation from FORD
FULLSCALE
Adam
Ontario, Canada
I’m sure you could probably get your $18 back if you asked since as others have mentioned the truck is advertised to have six, but that’s likely all you’d get from them. When I told my dealer they just took two out of another truck and put them in mine.
TheLoneRider
Wayne
WA
2019 Ranger Lariat SuperCrew 4x4, 2018 Escape Titanium, 2017 Mustang GT Convertible
My Lariat SCrew, build date 6/10/19 has all six
HenryMac
Mech. Engineer - Retired
My XL SuperCab build date is 07/19/19 it has 4, the center ones are missing.
I have the Ford ToughBed liner though and they sprayed it into the tapped holes. Any "easy" way to get the liner material out of the holes without screwing up the threads?
FULLSCALE
Adam
Ontario, Canada
My Line-X was sprayed over the holes and only two of the twelve caused problems. I ended up scraping the worst away with a utility knife then I ran a tap through the hole to clean the threads up.
Your truck and myself share the same birthday!
That's my girlfriends birthday too.
Mine was built on 6/12/19 so I guess if there are any problems/recalls we're in the same build batch. I have all 6 tie downs.
RavenRanger19
Sal
San Antonio TX
Mine only had 4. The tie downs in the middle were not there. The dealership said it was "optional" even though we couldn't find a truck on the lot that didn't have the middle tie downs. They were unable to provide me with any.
weasel1
Derek
Pembroke, Ontario
Nuclear Operator
Status
