Looks like 6 in most of the pics.How many truck bed tiedowns are in the new 2019 Ford Ranger?
My planned use, for this truck, is for work and not hauling around some kayak.
6 in the SuperCrew 5’ bed for sure on XLT and Lariat. XL might be different.Looks like 6 in most of the pics.
The truck could really use some high mounted ones as well. The problem with adding any is whether there's anything to bolt into--the inner wall of the bed isn't strong enough by itself.After using mine for a while, I have decided that I need additional tie-downs. I think the placement of the factory tie-downs is a bit goofy. I'd like the new ones to match what I already have there but I can't find them. Anybody know where they are available?
On a related issue, what kind of ropes or bungee cords do you use to tie stuff down in the bed? I am new to this--the Ranger will be my second Ford but first truck--and there all kinds of things advertised on Amazon.com and other sites, but what do you guys actually use?I used Bullring tie downs on my Colorado. Doesn't look like they're available for the new Ranger though.
Edit: I just spoke with Bullring and they are working on the tie downs for the Ranger this week.
ratchet straps for heavier loads, smaller lashing straps for lighter loads.On a related issue, what kind of ropes or bungee cords do you use to tie stuff down in the bed? I am new to this--the Ranger will be my second Ford but first truck--and there all kinds of things advertised on Amazon.com and other sites, but what do you guys actually use?
Is there a brand that you could recommend?ratchet straps for heavier loads, smaller lashing straps for lighter loads.
Also 6 in my xl, stx anyways6 in the SuperCrew 5’ bed for sure on XLT and Lariat. XL might be different.
A spider net is great for all sorts of loads. For heavier stuff, the ratchet straps are probably the best alternative. Sometimes I will use them both.On a related issue, what kind of ropes or bungee cords do you use to tie stuff down in the bed? I am new to this--the Ranger will be my second Ford but first truck--and there all kinds of things advertised on Amazon.com and other sites, but what do you guys actually use?
Thanks so much!A spider net is great for all sorts of loads. For heavier stuff, the ratchet straps are probably the best alternative. Sometimes I will use them both.
The spider web net would be something like this (there are a million variations):
https://www.amazon.com/8011101-Spidy-Cargo-Black-80111-01/dp/B000CEBX50
Thanks so much!I would only recommend using rachet straps at the factory tie downs. I use quick cinch(motorcycle straps) mostly. I used a spider net in the Colorado but it had 9 aftermarket bull rings. I only use bungees when I am tarping the load. I don't carry it in the truck all the time though, as I plan in advance what I'll be hauling or towing. I only carry rope for emergency. Well, I also have a tow rope stored in the truck.
