Ranger bounces on road!
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
You should be able to run lower pressure with larger tires, yes? The recommendation from Ford is only 30 PSI with everything factory. When I picked my truck up from the dealer, they had the tires at 48-49 PSI...since the max rating on the tire itself is 50, that's dangerous.
Not necessarily. Tire size doesn't really have a large correlation with tire pressure for the same vehicle, it's about the pressure on the road which is why the manufacturer's pressure spec is usually what you should be setting tire pressures to.
JasonTremor
2021 Ranger Tremor XLT
Fly to Hawaii, Oahu to be exact and I'll take you on a circle island tour in my '20 Lariat S/Cab with monoleafs...
If I could convince Ford that they need a mobile customer experience engineer, I could probably use per diem to cover the cost of that trip.
It all depends on your vehicle's gross weight...mine weighs 5,500 pounds with gear...I use the chalk test to determine my correct pressure...
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
True, if you're stock...mine weighs 5,500 pounds with gear...
Even at 5500 lbs, you're far from needing much extra pressure in the tires due to load. A few psi would be good, but much beyond that is overkill. Generally unless you're pushing max load of the tires, within 10-20% of manufacturer spec is best.
I don't know...my chalk test shows even wear across the entire tread and my mileage accumulated with the current set thus far confirms the PSI is correct and ride very comfortably...
Aonarch
Alec
North GA/ Montana
The multileaf rear springs on the Tremor package ride pretty smooth. It's not suv smooth by any means, but it is truck smooth. I run the recommended 39psi on the oem lt265/70/17 general at3's.
I haven't ridden in a ranger with the monoleafs to know how different it is.
My Tremor rides fantastic. So good that I don't want to mess with it.
Here
XLT
Circle? What about Ka’ena Point - I know our Rangers are pretty awesome, but I could barely get through parts of that on my mountain bike. ? Saw a guy in a Mercedes who tried to continue after 93 turned into a dirt trail and got high-centered - he asked me if I could help him. I was younger and a very powerful cyclist but who he really needed was Rory Irish from Moab, not some tourist on a mountain bike.
Cjohn8503
Denver
2021 ford ranger xlt
Personal chef
Until you replace the stock leaf springs you won’t be happy. They are super stiff to get the high payload capacity. I have the Fox 2.0 shocks and the Icon rear leaf set up and its a night and day difference. I don’t slowdown at all over speed humps (not bumps) and its as smooth as can be. Also no more rear end hop when hitting highway expansion gaps. Spend the money on the Icon leafs and keep your Fox 2.0s. Also, I run BFG KO2s at 40psi
Definitely curious about this. Can a dealership install all of this? I don’t know anything about installing myself and don’t have a garage
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Can they? Yes. Will they? That depends. Some dealerships don't mind at all and won't care, other than probably being a bit expensive.
You're more likely to find luck with a local suspension or off-road shop to do this for you than a dealership.
FatalException0E
San Antonio, TX, US
'19 Ranger Crew FX4 - Blue, '19 Subaru Forester Touring - White
You're better off with an independent shop, or a mobile mechanic. I found someone who came to my house and swapped out my shocks in my own driveway in a couple of hours. But remember when replacing front shocks/springs you'll need an alignment, and it is impossible for a mobile mechanic to do that. Places like Meineke do that, though.
Muffin1
NJ
These Icon leaf springs you speak of where to get them? and what do they cost generally? Thanks.
I found a 'Icon Vehicle Dynamics Co'. I'm guessing that's the manufacturer?
Hounddog409
Tod
Ohio
F150
Hello,
I just wanted some advice on what I can do on my ford ranger 2020 stx 4x4. I currently have Fox 2.0 shocks and does okay in my town on the road but it still bounces excessively on some potholes and bumps... It is uncomfortable for my children. I have tried the eibachs before the fox and those were no help at all. I love my ranger but if my family isn't comfortable on the ride then I may have to look for another vehicle. There are a lot of potholes and bumpy roads in my town.
Any recommendations please?
Replace rear shocks. Dont need to spend a lot of cash either.
I installed rancharos on mine. Made a world of difference.
Progeny2021
Charlotte, NC
I see the OP has a very different setup than mine. His is heavily modified while mine is stock. Just had Bilstein 4600s installed all the way around - it's like night and day. Tires at 32psi cold - still a pickup truck but much better ride and control than the 'pogo sticks' Ranger was originally equipped with.
HowIconic!
Georgetown TX
2020 Ranger
Retired Transportation Investigator
I still have the white wall Hankooks and run 42 cold. Rides great to me. Only wiggle wobbles going over speed bumps at an angle.
Muffin1
NJ
I found pricing for the Iconic leafs at approx $750+ for the pair then installation, so closing in on $1000, I haven’t done suspension mods in a long while but that seems pricey to me?‍
