Pre-Collision Assist Not Available
Glocker
Boca Raton
My hope is right there with your guess! Let's not return!
No didn't touch the tires at all...still at 42. Even talked to the dealer and he said that is correct for the tires etc.
Thanks again all!
OKay, I just saw what you're running. I think even with nitrogen, you should be filled up to factory spec.
NeptuneRanger
Scottsdale, Az / Carlsbad, Ca
2019 Ford Ranger XLT
Insurance Agency Owner AZ, CA, CO and WA.
Thanks again all!
You bet... the old adage if it works don’t fix it, just FYI, maybe after the message seems a distant memory go to your door pillar and look at this sticker. As long as you have stock tires on pavement, the info on your sticker is the true factory spec regardless of what someone told you at the dealer. I hope you will love your truck as much as we love ours. Very happy for you !
donkeylarry
donkeylarry
Collinsville, OK
2020 Ford Ranger XLT
You bet... the old adage if it works don’t fix it, just FYI, maybe after the message seems a distant memory go to you door pillar and look at this sticker. As long as you have stock tires on pavement this is the true factory spec regardless on what someone told you at the dealer. I hope you will love your truck as much as we love ours. Very happy for you !
Thank you brother! I could hardly love it much more than I do at this point!
I'm going back in soon and I'm going to just give them the "WTF" look and ask for their reasoning behind the inflation and the comments received here. I'll re-update just for posterity.
Appreciate everything!
NeptuneRanger
Different trucks have different tires. So I just want everyone to know that your attached picture is not all encompassing. Some trucks are supposed to be at 35psi, some are supposed to be at 30psi, maybe there's another option out there too.
In the end, put the tires on your truck to whatever pressure you want.
Totally agree, I was referring to stock tires used on pavement in stock trucks only, everyone needs to look at their own truck pillar label and account for their situation.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Ford General Service Bulletin Dated January 29, 2021 Has some info on the system.
I remarked in a different thread about my truck's intermittent availability of ACC and that document makes two points that levelling the truck and/or aftermarket facia might affect it.
Along with the modest Eibach front end level I have the Ford licensed Putco lower valance fill with the cutout for ACC radar.
