On board Air setup on your Ranger
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
Hi, just want to start a thread about onboard air and also to see other members setups.
I also wanted to share where I put mine and why I went with the ARB twin compressor.
It was abit of a pain trying to run wiring from battery to bed...but it’s all worth it in the end.
Some of you guys already know, I modded one of the factory swing out tool box to hold my ARB compressor.
https://www.ranger5g.com/forum/thre...m-swing-out-tool-boxes.2397/page-2#post-31548
Anyway, I’ve been lucky with ARB twin compressor in the past with my Jeeps, that’s why I chose to install it in the Ranger. Aside from airing up, I also like the versatility to be able to run air tools (135 up to 150 psi per ARB) when needed.
During a test I was surprised how quickly the Aircat/ ARB combo took a lug nut off with ease.
So please, If you have different locations or ideas for onboard air, you can share them here.:)
I know under the hood behind the drivers side headlight, there’s a small area that can prob fit a small compressor, but I couldn’t use it cause the ARB twin is huge. LoL.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
I don't have my truck yet but I was thinking about trying to find a hole between the frame somewhere. Maybe in front of the gas tank? Not sure if that's even practical. It would require custom brackets and splash shields of course.
KnightRanger
KnightRanger
USA
I have a powertank I swap from truck to truck. Portable and it will run anything. I'm use to using it to air up 37's so it should last on something like this a very long time.
How long does it last or how long between refills?
I would like to try a powertank, but theres not alot of CO2 fill stations in my area.
KnightRanger
KnightRanger
USA
mike
Hawaii
2019 Ranger Lariat Supercab, Nissan Rogue
Here's a good comparison from a couple years back: Man, that CO2 system is fast. For the DIY type, it can be built pretty cheap. hmmm
KnightRanger
KnightRanger
USA
Tested the setup today at a 4 wheel drive fishing area, Robert Moses State park (Lots of loose soft sand and deep ruts).
Using Staun deflators, each tires were running at 18-20 psi. The ARB twin aired them all at 2-3 minutes each back to 37psi. (with me checking the tire pressures in between). It definitely cut down my air up time, so I’m happy. :)
Mustang2Ranger
Garrett
Southern California
I have a 2000w generator I will be bringing on all of my trips. Charge stuff, light stuff, even run a space heater in the tent if needed. Have a 2gal Kobalt compressor Home Depot special I will bring along as well to air up. And an emergency 12v compact compressor as a backup
Your setups look really nice but too fancy for me right now lol
MrRisk
Nick
Ranger XLT
Mechanic
I really like this!!!
Cool set up...is that a one gallon tank? I have a Harbor Freight Fortress silent compressor that I plan installing in the bed along with my Honda generator after I get a Diamondback cover installed...
KnightRanger
KnightRanger
USA
Thanks, it’s an ARB 1 gal aluminum tank.:)
Have a safe and Happy 4th July everyone!
Andy
Andy
I’ve been using my Dewalt cordless air compressor. Able to air up from 15-40 psi in 20 seconds per tire. Decided it was the best if both worlds in compromise instead of installing one on the truck.
