Oil Catch Can. Yes or No?
Do you have a catch can?
  • Total voters
    44
u wish u could ride
robert
lakeland florida
19 xlt in blue
building maintenance
How does the carbon get into the catch can...
he means the oil vapors .you stickler you!! I figure with all the fuel in these things catch cans ford is for sure using it to keep the intake valves clean . so maybe taking that nice cleansing fuel out of the pcv system you maybe not helping the valve cleaning. they must of learned something with the millions of ecoboost engines on the road.
Jacob
Jacob
USA
2019 Ranger XLT Sport 4x4
I’ve actually been thinking about that. Here’s the only thing I can wrap my head around. So the fuel goes through the PCV without a can and if they are really putting extra in there, then it should clean and burn up its second time around. If this was the case shouldn’t there be no fuel in my oil since I have the catch can? Unfortunately my ranger suffers the same as many others, fuel finds its way into my oil. Mine isn’t as bad though because it’s never enough to change my oil height on the dip stick.
you could have something there tho
Doc
Doc
Live oak fla
I know how a catch can works however there should be no carbon in there..the carbon is what’s burned on to the valves..fuel in the oil is an over pressure fuel pump, or a bad injector, or unseated rings..
Regards
Jacob
Jacob
USA
Regards
So explain the carbon I have found on the baffles and within the can when cleaned?
db_tanker
Darrell
Process Professional
jacob,
I am shooting in the dark here but would it have something to do with a combination of us having a boosted engine AND the fact that regardless of how tight the tolerances are you will have blow-by regardless on any engine. These two items combined together with other outside forces (driving style, fuel differences, oil differences, impurities in both, hiccups in the ignition control from the ecu, etc etc) all can combine to cause carbon and such.
I am sure that others can and will have additional data here but just from my experience this is what I believe to be the reason for the carbon.
And because its carbon it ultimately does this -
Porpoise Hork
Bret
Houston
IT
Regards
You can read up on why carbon buildup is an issue with GDI engines from this report on dual port fuel delivery systems (Port Injection & DI). The author explains why there was the push to the DI fuel delivery, the problems it causes and how manufacturers are working to solve it.
GDI sprays gasoline directly into the combustion chamber under much higher pressure (2,200 psi or more) than PFI’s intake manifold spray (40-60 psi). Increased GDI contaminants blow past low-tension piston rings into the oil sump. Then, positive crankcase ventilation (PCV) passes oil-laden contaminants into the intake air stream where, according to SAE Paper 2002-01-2660, oily PCV crankcase vapors and droplets combine with exhaust gas recirculation carbon particles and heat to layer over sticky intake valve coatings and bake into deposits. This creates larger, harder and more crusty deposits in the fuel system.
Article found here.
Another thing that can be done is using oil specially formulated for GDI engines. This article goes into detail on the issues the implementation of GDI has caused for oil contamination, and how improved technology in oil additives to further reduce the carbon deposit buildup. It also outlines differences in oil sold here vs in Europe and why they are not seeing the same buildup issues that we are.
Motor Oil
Hope this helps clear up some of the confusion as to how, why this is happening on DI only engines.
weasel1
Pembroke, Ontario
Nuclear Operator
I'm curious if a methanol/water injection set-up would be of benefit to keeping the valves clean.
jrscobra
Jaime
Chattanooga
2019 Ford Ranger lariat Crewcab
Fleet Vehicle Sales at a Ford Dealership
This is one of the best threads I've ever read. I'll be ordering my catch can for my 19 Ranger as well as my wifes Escape. I see no reason to not have the extra protection with such a low cost to add it as well.
Sashimi_Moto
WA
2012 E450 C-Class, 2019 Ranger Lariat 501A FX4
I have a question about the Quick Release fittings. On the PCV side the fittings the male end of the fitting is 1/2".
I want to fit the JLT can to the CCV side but once I had the QR fitting separated from the intake tube I noticed they were larger - 5/8" or maybe 3/4". It would be the cleanest install to remove the 1/2" fittings that came with the JLT kit with the proper size and the bang - CCV side solved.
Anyone know where I can find them?
Picture for reference: This is where I will tie-in the JLT can setup.
EDIT: Nevermind - a major part of finding a thing, is knowing what the thing is called. Once I discovered these were called Bundy Quick Connect lines the search got a whole bunch easier.
I'll post up once I've installed it.
Porpoise Hork
Bret
Houston
IT
So I have been doing some reading on this engine design as well as information put out from Mishimoto. It appears that Ford has been aware of the valve deposit issue for some time and has installed components to mitigate it. In the Mishimoto's engineering articles ( Pt 1, Pt 2, and Pt 3) they did fairly extensive testing on prototype catch cans and reported that the 2.3L in our trucks has an air/oil separator integrated the PCV system. In pt3 they show the results and it appears that their catch can captured separated out what appeared to be a water/fuel mix from the PCV system with almost no oil in it.
Now it's well known that engine blow-by is significantly higher during the break-in period. It has also hotly debated for decades on the length of time needed and exact process to properly break in a new engine, but the general guidelines are the time period being somewhere between 500 and 2000 miles. Once broken in the engine blow-by does drop significantly as the rings (the primary source of blow-by gasses) seat in and a new baseline can be set for your engine's blow-by level.
The Mishimoto test results showing the capture and separation of the heavy fuel laden mix with minimal oil in it shows how efficient the factory oil separator system actually is. Ford's system appears to not only do an impressive job separating oil vapor before being returned to the intake plenum, but also how well it captures the unburned fuel that made it past the rings during the compression stroke preventing it from mixing with the oil in the crank case. This leads me to think that Ford's engineering team saw how the valve deposit problem was being resolved or largely mitigated from the Ford Performance team's oil/air separator for the 2015-2020 EcoBoost-equipped Mustang 2.3L and 2.3 HO engines. With it in place it allows fuel particles to come in contact with the valves and possibly prevent or significantly reduce the carbon buildup and excessive oil consumption. It also may by why they have not included the 2.3l in the dual port injection setup that the larger EcoBoost engines are being updated to. That would explain the implemented a very similar solution on the Ranger version of the 2.3L.
This makes me wonder if similar results are seen across the board, and adding a catch can to the PCV system, is actually preventing the system from working properly by filtering out the unburned fuel before it makes it back to the intake valves. The only way to know if this theory is correct is to run a bore scope down and inspect the valves on 2.3l engines with the factory separator installed as well as some with a catch can to see how the valves look over the life of the engine.
Anyway.. I'm not an engineer so I may be completely wrong but it was something I started to wonder as I was researching the different catch cans and found this additional information about the 2.3L in the Ranger.
HI PH,
I are a train driver... I find your assessment above to be very interesting, well done and well stated!
Best.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I regularly check my can and there's still plenty of oil. It's not an insignificant amount. I'm just over 11,000 miles.
