HenryMac
OK, I'll bite. What are we looking at here Doc, more details please.
2000 miles later, no muss, no fuss!
Regards
Doc
If that's a filler tube breather, isn't it spewing oil vapors into the engine bay?
Regards
Doc
It’s a breather with a ball valve and spews nothing..except crankcase pressure..probably some un noticeable oil vapor too..it only opens during boost.OK, I'll bite. What are we looking at here Doc, more details please.
How about a link to the manufacturer?It’s a breather with a ball valve and spews nothing..except pressure..
CFM Performance billet valve cover/ oil filler breather. 2015/2019 mustang Ecoboost.How about a link to the manufacturer?
Thanks Doc.... https://www.c-f-m.com/performanceparts/pc/Valve-Cover-Breathers-c744.htmCFM Performance billet valve cover/ oil filler breather. 2015/2019 mustang Ecoboost.
Regards
I'm trying to understand this catch can stuff. It looks to me that the custom oil filler breather filter (CFM) would eliminate the need for the crank case catch can. Is that the idea? Thanks in advance.2000 miles later, filter is still clean. no muss, no fuss!
Regards
Doc
Yes , this only opens during boost ( check valve and baffles not epa friendly) and vents to the atmosphere. The use of a catch can is subjective. With all this crap about gas entering the crankcase, it might be a good idea to have one.I'm trying to understand this catch can stuff. It looks to me that the custom oil filler breather filter (CFM) would eliminate the need for the crank case catch can. Is that the idea? Thanks in advance.
Doc I just recently got one of these valve cover breathers and installed it on a Saturday and drove with it until Monday evening. When the engine would warm up and let's say i would stop somewhere run in and come back out and start my truck I would have a noticeable fuel smell coming into the cabin via the a/c system. And then when I went to inspect it Monday evening I noticed it had been "misting" a fine oil/fuel mixture all over my engine bay that reeked of raw fuel. Pulling it off the valve cover you could smell fuel all over the breather and it was slick with a fuel/oil mixture. Yours is not doing this correct?Yes , this only opens during boost ( check valve and baffles not epa friendly) and vents to the atmosphere. The use of a catch can is subjective. With all this crap about gas entering the crankcase, it might be a good idea to have one.
So far, I have no gas smell in the crankcase and my plugs are clean.. Addendum , if the engine did not have a reasonable break in, that means occasionally bringing it to rpm, the rings may not properly seal causing blow by..
Regards
Correct, you should not have a raw fuel smell coming from the crank case. I would have Blackstone test your oil..Doc I just recently got one of these valve cover breathers and installed it on a Saturday and drove with it until Monday evening. When the engine would warm up and let's say i would stop somewhere run in and come back out and start my truck I would have a noticeable fuel smell coming into the cabin via the a/c system. And then when I went to inspect it Monday evening I noticed it had been "misting" a fine oil/fuel mixture all over my engine bay that reeked of raw fuel. Pulling it off the valve cover you could smell fuel all over the breather and it was slick with a fuel/oil mixture. Yours is not doing this correct?
Regards
Just sent it off today! Im thinking I definitely have something going on for sure I will report back as soon as I get my report back. which should be possibly Friday/Saturday or Monday depending on Blackstone but I sent it priority mail 3 day.Correct, you should not have a raw fuel smell coming from the crank case. I would have Blackstone test your oil..
Regards
