Oil Catch Can. Yes or No?
Do you have a catch can?
  • Total voters
    44
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Hi all, new member here. My first mod to my 2019 Lariat was a catch can after a lot of internal debate. At the time the only two made-for-the-Ranger cans were the JLT model (out of Chesapeake VA - my home state) and the one I went with from UPR Products here in my new adopted home in Florida. The JLT would have been fine, far easier to install since the existing hose from the PVC would snap into their line as opposed to the UPR model where you have to get up into that extremely small area where the valve stem exits the engine. The UPR requires completely removing the short U-shaped Ford EGR hose.
I went with the UPR in spite of it being 25% more expensive and a significant pain to install. Fortunately being a few miles from their HQ in Lake Worth I got assistance when I got frustrated.
The UPR is a larger volume can, and I upgraded the check valve (JLT doesn't use one). With the JLT you unscrew the container, UPR has a valve mounted for draining. They use some high end materials.
JLT had an attractive bracket for theirs, the UPR is a little more generic.
I didn't have the bandwidth to design my own even with some very high end catch can components out there with sight glasses and exotic filtration. Overkill.
For just under $200 I figured this was my target.
Maybe the truck will run smoother with less extra byproduct going in the intake. After about 2300 miles I checked drained the can, about an ounce plus a little more fusel-smelling dark thin liquid. I installed the can at around 500 miles and as of today have about 3500 on it.
If there is an initial benefit to mileage, I bet it's negligible - maybe emissions are cleaner (if that matters). I didn't do this expecting any boost to performance. I'm not sure idle or throttle response is significantly better. I keep my cars for about ten years on average, so this was for the long haul. If someone else winds up with this truck way off in the future, they'll need to be mindful of draining the catch can; the reason these things aren't included by Ford. Guess I need to come up with some type of signage for the engine bay.
Edit to add links: https://www.jlttruecoldair.com/jlt-3-0-oil-separator-2019-ford-ranger-2-3-ecoboost-driver-side/
http://www.uprproducts.com/ranger-billet-single-valve-catch-can-separator-ecoboost-19.html#1
tugger50
Arlington, Wa
2019 XLT RANGER SUPERCREW, 2002 F-350 7.3 POWERSTROKE DIESEL
2000 miles later, filter is still clean. no muss, no fuss!
Regards
Doc
I'm trying to understand this catch can stuff. It looks to me that the custom oil filler breather filter (CFM) would eliminate the need for the crank case catch can. Is that the idea? Thanks in advance.
Doc
Doc
Live oak fla
Yes , this only opens during boost ( check valve and baffles not epa friendly) and vents to the atmosphere. The use of a catch can is subjective. With all this crap about gas entering the crankcase, it might be a good idea to have one.
So far, I have no gas smell in the crankcase and my plugs are clean.. Addendum , if the engine did not have a reasonable break in, that means occasionally bringing it to rpm, the rings may not properly seal causing blow by..
Regards
Sashimi_Moto
WA
2012 E450 C-Class, 2019 Ranger Lariat 501A FX4
Alright I ordered the Mishimoto setup to keep my valve clean but I also took a chance and ordered M-6766-A23S from Summit. This is the RH side that keeps the turbo happy and it's made by Ford. It's for the 2.3L Mustang so it may not fit the Ranger - we'll see.
Once everything arrives I'll see how it goes.
OWSportninja
Nathan
Burleson, Tx
2019 Ranger Sport SuperCrew 2wd
Regards
Doc I just recently got one of these valve cover breathers and installed it on a Saturday and drove with it until Monday evening. When the engine would warm up and let's say i would stop somewhere run in and come back out and start my truck I would have a noticeable fuel smell coming into the cabin via the a/c system. And then when I went to inspect it Monday evening I noticed it had been "misting" a fine oil/fuel mixture all over my engine bay that reeked of raw fuel. Pulling it off the valve cover you could smell fuel all over the breather and it was slick with a fuel/oil mixture. Yours is not doing this correct?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Catch cans are not about excessive blowby. It's about stopping oil and junk from going back into the intake system. Running open breathers are a band aid for engines with bad rings.
Doc
Doc
Live oak fla
Correct, you should not have a raw fuel smell coming from the crank case. I would have Blackstone test your oil..
Regards
Doc
Doc
Live oak fla
Regards
Edit: These filters need to be cleaned after every oil change
tugger50
Arlington, Wa
I installed the valve cover breather and have not seen any misting or fuel smell.
OWSportninja
Nathan
Burleson, Tx
Regards
Just sent it off today! Im thinking I definitely have something going on for sure I will report back as soon as I get my report back. which should be possibly Friday/Saturday or Monday depending on Blackstone but I sent it priority mail 3 day.
Jacob
Jacob
USA
2019 Ranger XLT Sport 4x4
Hey y’all, went with the Mishimoto catch can after researching catch cans for awhile. Needless to say I’m sold on them. Here’s what I caught after only 1000 miles of the can on my Sport XLT ranger.
Jacob
Jacob
USA
Also I know some talked about putting valves on the bottom of the can to ease the draining. I’d recommend taking off the whole can. I ended up hitting mine with brake cleaner as I had slimy chunks in it.
deton8r
Snohomish, WA
2019 Ranger Lariat FX4, 2008 F150 Foose Edition, 2006 Pontiac GTO, 2004 Buell XB12S, 1995 Yamaha TW200
To those running the CFM breather, why did you order the Mustang EcoBoost (1-0103-3) version and not the one listed for the Focus RS (1-0103-9)? Are they the same? The part numbers are slightly different.
