Need Wiring Schematics Related To Interior Lighting Activation/Doors
Discussion in 'Maintenance - Break-in / Oil & Fluids / Servicing' started by SRAces, Mar 14, 2019.
  1. SRAces
    SRAces Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ford Ranger, 2015 Mercedes-Benz GLA, 2004 Mercedes-Benz SLK 230 Special Edition
    Oct 17, 2018
    Lake Park, GA
    134
    Working with F150LEDS.com on using one of their bed lighting kits for my Ranger. The key is determining where to tie in to the unlock/lock function that activates the interior lights when the doors are opened and closed. Anyone been down that road yet or have a way to get the wiring schematic? They went through the shop manual PDFs on this site and didn't find the diagrams.
    Monty likes this.
  2. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    Here is their instructions for the F-150 installations.
    We use the wiring harness/bundle that is located under the door sill in the rear of the truck!
    Here is a copy of our running board/bed light kit instructions!
    Automatic Running Board/Bed Rails/ Door Sills LED F150 Wire guide
    *we recommend checking all connections with a voltage multimeter first to ensure
    proper wire selection.
    ****Use as a guideline only. When in doubt, use a multimeter and probe the wires to be
    sure.
    F150LEDs is not responsible for any damage to property or person(s).
    ***Connection points at rear passenger door kick panel. You can use this wire guide
    for the door sills or to power LED step lamps , LED bed lights etc etc. It is hot when the
    cargo light / interior lights come on and is not door specific. Open any door and the wire is
    hot. Close the doors and it'll go cold when the lights go out.
    1996-03
    Ground - light green & orange
    Power - black and light blue
    2004-2008
    super cab/super crew
    Passenger Rear – Black with Light blue wire for power & black for ground
    Regular cab or super cab without the overhead rail
    Passenger Rear – Light green with orange wire is hot. black is ground.
    *if Light green with orange wire not present look for Black with Light blue wire
    2009-2010
    Power - grey wire w/ violet strip. Black is ground.
    Alternative Passenger Rear - White is hot. Black/Yellow is ground.
    2011-2012
    Alternative Passenger Rear - Solid purple is hot. Black/Yellow is ground.
    2013
    Alternative Passenger Rear - Thin solid purple is hot. Thin black/yellow is ground.
    2014
    2015+
    Grey w/ violet stripe for power. Black/yellow for ground.
    Alternate power options - violet wire or yellow w/ green stripe wire.
    Alternate ground wire option is black/white or all black.
  3. j0shm1lls
    j0shm1lls Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    Oct 30, 2018
    SoCal, USA
    623
    479
    Garage Profiles:
    not quite a wiring schematic, but the guys at ADD Offroad have which wire to tap into for their rock sliders lights listed in their install instructions...
    https://www.addictivedesertdesigns....ider-Side-Steps-Installation-Instructions.pdf
    SRAces likes this.
  4. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    Josh,
    Thanks for the great help! I will assume those lighted steps come on based on the doors being unlocked or the interior lights coming on.
    j0shm1lls likes this.
  5. Monty
    Monty Well-Known Member
    First Name:
    Vehicle(s):
    Honda Element
    Nov 25, 2018
    Prattville
    65
    27
    Patiently waiting for same info. Bed LED kit needs to turn on/off with door unlock/lock.
    MT19RANGER likes this.
  6. j0shm1lls
    First Name:
    Josh
    Vehicle(s):
    Oct 30, 2018
    SoCal, USA
    623
    479
    Garage Profiles:
    Yep, this wire should be hot when the dome light is on.
  7. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    Close to pulling the trigger on the F150LEDS.com bed lighting kit. Waiting on them to answer one question for me. Those ADD instructions were a big help. Seems like routing the wires to the cab is the most work. Just basically tapping into the dome light wiring and a common ground wire. Simple enough. Should have them ordered today and will post when I get them installed. Will take pictures on my installation and the steps.
    Monty, djrobb and j0shm1lls like this.
  8. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    Light kit on it's way. Will take detailed pictures and instructions as well as installed pictures. Should have a "Garage" entry put up by the weekend.
  9. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    The detailed pictures and instructions are for F150LEDS.COM as well. They will use my pictures and instructions for their kits.
  10. SRAces
    First Name:
    Vehicle(s):
    Oct 17, 2018
    Lake Park, GA
    134
    Just waiting on the F150LEDs bed light kit to come in. Pulled some panels last night and determined where I will run the wiring into the cab. The plan is to hook up the lights so they can be activated in conjunction with the interior lights and also by the cargo light button on the left side of the dash.
    Rinn69 likes this.
Share This Page
