TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 47
- Messages
- 4,069
- Reaction score
- 10,330
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #1
Our modern autos are almost too complicated for their own good! The old rules no longer apply, and our new autos are much more fragile than our largely mechanical cars of the past. I've purchased two items that I think may help me (and maybe others) avoid one of the pitfalls, short battery life.... and the accompanying problems of having to have your truck systems resetting to defaults and needing to relearn your driving style. Another member noticed transmission shift issues beginning after the battery was removed.
About 10 years ago I purchased a BatteryMINDer Model OBD-12 Desulfator for 2 of my vehicles. It is a simple to hook up device that breaks down the sulfur crystals on the lead battery plates whenever your engine is running and charge voltage is >13.5v. Since installing, my batteries last 3x longer than my neighbors. I got 10 years out of my last two batteries in both vehicles that had these Desulfators installed in them.
I have just ordered another one for my 2020 Ranger. Prices have gone up since then (was $35) and the best price I could find was at an RV shop for $82 delivered to the door. This website is a little tricky and has a link to click to get the lower price of ~$65 + tax + shipping instead of the price listed at ~$79.
Here is a picture of the BM desulfator installed in my 2005 Ranger. It is sitting on the antilock brake module next to the battery. Nothing more than Velcro holding it in place. Been there for a very long time, 10-15 years. I've lost track of when I purchased it. I just put battery #3 in the truck 3 months ago. So 2 batteries replaced in 17 years, and the first one went a few years without the desulfator installed.
The second item was purchased quite a while back when I bought the truck. It is a small 12 volt adapter that is designed to keep your auto's computer settings when changing batteries. This means you must change the battery before a catastrophic battery failure occurs. You simply plug the device into you trucks Diagnostic port, and plug it into either a 9V battery (good for ~30 minutes with a new 9v battery), or a 110v wall outlet with a 12V wall wart PS. Then remove and replace your truck battery. This keeps power to your Truck systems while you switch out your battery. I bought it on a whim, and thought I'd never need it. Here is a similar device available from Amazon.
I will be connecting m BM Desulfator to the posts ( I will not be disconnecting the battery, just taking off the nut). And yes, it as simple as that. The pigtail is used when you wish to charge the battery through the desulfator. Simply plug your charger into the pigtail, and it will charge and desulfate at the same time. The same is true if you connect to the + battery post and to the nut before the BCM on the negative terminal.. The desulfator goes to work when it sees a charging voltage, be from the alternator or an external charger.
I am attempting to revive a long discharged / discarded sealed AGM battery (made in Jan 2006) through the BM desulfator charger
(I will keep updating the progress by editing this entry.)
Battery is rated at 725 CCA.
Results of Initial health check (It failed while attempting to charge it with another very expensive Schumacher "smart" battery charger. )
000 CCA - 0% of CCA of new Battery Voltage = 4.v Resistance = 31 Ohms BatteryMinder level = 1 Poor
UPDATE: 12 Hours from Start
123 CCA - 17% of CCA of new Battery Voltage = 13.31v Resistance = 20 Ohms BatteryMinder level = 1 Poor
UPDATE: 24 Hours from Start
261 CCA - 36% of CCA of new Battery Voltage = 13.35v Resistance = 14 Ohms BatteryMinder level = 2 Fair
UPDATE: 36 Hours from Start
332 CCA - 46% of CCA of new Battery Voltage = 13.35v Resistance = 10 Ohms Battery Minder level = 2 Fair
UPDATE: 48 Hours from Start
375 CCA - 50% of CCA of new Battery Voltage = 13.35v Resistance = 8 Ohms BatteryMinder level = 2 Fair
UPDATE: 60 Hours from Start
430 CCA - 60% of CCA of new Battery Voltage = 13.26v Resistance = 7 Ohms BatteryMinder level = 3 Good
UPDATE: 72 Hours from Start (things seem to be slowing)
444 CCA - 61% of CCA of new Battery Voltage = 13.26v Resistance = 7 Ohms BatteryMinder level = 3 Good
UPDATE: 84 Hours from Start (things seem to be stalled but it was very cold last night) Going to give it 1 more day to see if trend holds.
450 CCA - 61% of CCA of new Battery Voltage = 13.26v Resistance = 7 Ohms BatteryMinder level = 3 Good
UPDATE: 96 Hours from Start (very cold again last night, but a major positive change)
658.6 CCA - 91.5% of CCA of new Battery Voltage = 13.73v Resistance = 5.5 Ohms BatteryMinder level = 4 Excellent ( this battery is now reporting better condition than my 2020 Ranger battery!)
UPDATE: 108 Hours from Start (A reversion back down!)
462.9 CCA - 63.9% of CCA of new Battery Voltage = 13.29v Resistance = 6.9 Ohms BatteryMinder level = 4 Excellent ( this battery is now on par with my 2020 Ranger battery!)
If the battery does not have shorted cells there is a good possibility of bringing it back to 80% or better of its original capacity. It just takes some time. Desulfating uses very little energy. My Battery Minder charger was putting out 8 Amps early on, but now it is simply maintaining and desulfating.... at a cost of ~35 cents / month.
My other smart chargers reported "battery bad" and gave up. My very old dumb chargers would have boiled the water out of the battery with 15 Amps going in.
I know there are several very nice modern chargers on the market, but I have no personal experience with them.
-T
-T
