- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,456
- Reaction score
- 8,514
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Now that I know they are not OEM Led, It should be an easy fix with Forscan as it just needs to have the correct setting,
Since you are new here, you need to get Forscan and download your as built files from ford.
and check these specific as built files, I am pretty sure that the headlights were swapped and no Forscan changes were implemented or not correctly set as this would explain the reason for the DRL flicker. The DRL source needs to be set correctly as the truck thinks that the DRL is stil Low Beam headlight bulbs and not the LED strip
Here are my swap notes that are posted in the Forsscan Wiki
FORScan Crowdsourced Wiki | Page 41 | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
