Lariat Headlight OEM
ForgedGreen
Brett
New York
2022 Ford Ranger
Equip Eng
Looking on parts websites, I'm seeing two different part numbers for the Lariat Headlights.
There's an "Assembly" Version, part# KB3Z-13008-N/P
Then there's a "Housing" Composite version, part# KB3Z-13008 - B/D
Anybody Know the difference? Im assuming that maybe the Assembly version comes as an entire setup and Composite you have to use LED bulbs? Correct me if I'm wrong
Current Prices (using OEM Ford Parts Direct)
I do not know the specific difference between them, but the (-) indicates revision level.
My (LED) delete swap from Halo to LED, I purchased these part numbers for my 22 Lariat.
Keep in mind that there is only (1) replaceable bulb on the LED assemblies and that is the (Turn Signal) so the (B) and (D) diagrams can be misleading and they are most likely (Halo Units)
I ordered these:
KB3Z-13008-A (Right)
KB3Z-13008-C (Left)
My guess you want these (P) & (N) Current revision level of mine as far as I can tell
LED Headlamp Assy
Left: KB3Z-13008-P - ($1109.59)
Right: KB3Z-13008-N - ($840.74)
LED Headlamp Assembly:
Left: KB3Z-13008-D - ($1100.00)
Right: KB3Z-13008-B - ($1100.00)
