CHS
chris
Crossville, TN
(Ruby) 2021 Ford Ranger Lariat 4X4
the other day, Ford updated my sync, it is now 3.4 and my map is updated. So I did not have to do anything. It just updated
Map updates are a separate update. Maybe just the display are what updated.
Fx4ranger2019Larait
Ricky
SoCal
2019 Ranger FX4 Larait
Sprinkler Fitter
Updated to Sync 3.4 and can’t adjust brightness. anyone figured out how you do this? Or is there something that can be done in Forscan.
Thanks
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
Thanks
The brightness can be adjusted under ā€˜Settings’, then on page 2 ā€˜Display’
Fx4ranger2019Larait
Ricky
SoCal
Sprinkler Fitter
It’s greyed out can’t adjust in settings…. Probably should of started with that lol
alcohenusa
Alan
CO
Getting back to basics then….
Did it work before the update?
What version is installed?
Did you upgrade via wifi, Ford USB process, or Cyan Labs?
Fx4ranger2019Larait
Ricky
SoCal
Sprinkler Fitter
It worked before update. Not exactly sure on version think it’s 3.4 and updated via Wi-Fi last weekend. Only noticed it driving to work in AM it too bright at least I can turn off the screen still
alcohenusa
Alan
CO
If it were mine, I would pull the fuse that controls sync, or disconnect the battery for a short time to get the hardware to reset.
You can also try doing a master reset which sometimes cures issues, but then you’ll have to redo any customized options/settings, etc.
If you disconnect the battery, then check the owners manual for things to be aware of when you change the battery (such as having to reset the auto up/down driver’s window).
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
You can't adjust the brightness with the headlights in the "off" position. Turn them on (auto should work too I think) and try again. Also I can't recall if that was one of the settings tied to the vehicle in motion or not, so keep that in mind too.
Fx4ranger2019Larait
Ricky
SoCal
Sprinkler Fitter
That didn’t work. I messed around with Forscan last weekend for the first time is it possible there’s something in there that could of done it?
alcohenusa
Alan
CO
I guess I learned something today. Went back to mine and with the headlight switch in OFF, the setting does indeed get grayed out. Mine is always in AUTO and I never thought about it.
Rviator
FLA
retired aerospace engineer
Mine auto updated the build from 21020 to 21194. Anyone know what's different?
Dgc333
21 Ranger Lariat
The only thing I know of in 21194 was it fixed an issue introduced with 21020 where TravelLink wasn't showing traffic conditions on the nav map.
Rviator
FLA
Previously TravelLink (weather radar) would only work less than 1/2 the time so that sounds good to me.
Fx4ranger2019Larait
Ricky
SoCal
Sprinkler Fitter
I’m going to try master rest see what happens
Did the master reset and still not working
