brroberts
- First Name
- Randy
- Joined
- Aug 20, 2021
- Threads
- 10
- Messages
- 452
- Reaction score
- 1,051
- Location
- Overbrook, KS
- Vehicle(s)
- 2021 Ford Ranger XLT 2WD SuperCab
- Occupation
- audio / semi retired
Never, but I have a 2wd
Always a good idea to use it every once in awhile for that reason.He was told to switch from 2 to 4H and 4L once every 6 months just to make sure everything's working correctly. I do the same, 4H and 4L in some sand just to exercise the units.
Only times I use since getting my ‘19 are in snow and ice, I have a steep street to get up. Normally 4H is fine but sometimes L is neededI was again doing some forest work as now is the best time to cut trees, days are getting longer and weather is getting about right to do that. Driving to the forest is challenging even in summer and in winter/spring you get extra enjoyment of snow and mud.
Before I plowed to the forest I turned on 4L. And that got me thinking how ofter people really need 4L.
I use it couple of time a week during forest stuff, but outside of that I use it next to none.
How about you?
I use it when driving up on ramps to change the oil that doesn't even need changed. I never off road and never use the Ranger as intended. It is such a diva, but I still love it.I was again doing some forest work as now is the best time to cut trees, days are getting longer and weather is getting about right to do that. Driving to the forest is challenging even in summer and in winter/spring you get extra enjoyment of snow and mud.
How about you?
Your boat ramp climbs 150 vertical feet? Holy crap. Where are you boating, in a quarry?I use 4lo when I'm hauling my boat out.
Our ramp is STEEP, the boat+trailer is ~6300 pounds. I just keep the wheels straight and use crawl control to go up the ramp at a leisurely 2ish mph. Once I'm over the top I shift into 2wd.
I tried to haul out at my ramp with a 2wd truck once, it did not go well. Rear tires are on slime at the bottom of the ramp, and like I said it is steep. I think 15% grade (9 degrees according to the off-road-ometer), and climbs ~150 vertical feet at that grade.
Better to use it when not needed than to try to use it and find out it doesn't work due to, well, lack of use.Also like Andrew27 says: best to give a whirl every now and then. So you long as you go straight, I see no problem engaging it on pavement for a few feet. If you're paranoid, find a dirt lot to do it.
I like to switch my transfer case into 4hi and 4lo every once in a while, not because I think they need to be worked out or anything, but rather so that I know the electric shifter is still working and that nothing has gone wrong with the transfer case. I'd rather find out something is wrong when I don't actually need 4wd, than find out something is wrong when I DO need it.
I tell my wife the same thing?Better to use it when not needed than to try to use it and find out it doesn't work due to, well, lack of use.
