- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,696
- Reaction score
- 8,998
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
That won’t help much, as the rotation force is clockwise (towards the support where the hose breaks)Well I’m thinking maybe get some coated braided steel cable and run it along the outside of the hose. Do loop crimps around the hose mount points. So if the hose lets go then hopefully it won’t wrap around the clutch. Just a thought.
If any mod that could be done would be to run a solid tube in the rubber tubes place.
But I cannot find a detailed answer as to why it is designed the way it is.
I know that I can see some flexibility in the hose as the clutch engages and disengages, so the design works as intended, but wonder if it was modded to be rigid would it cause issues with the clutch.
More importantly why - when the clutch fails , is it intentionally designed to rip the hose and harness with it?
Or is this an oversight by the engineers?
I am surprised that there had not been anything from Ford in a SSM or TSB on this issue, it appears to be common and this forum only accounts for a small percentage of owners.
