Help! On side of highway… trans issues
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
Going about 90 in my 2023 Ranger. Nothing special.
Suddenly drops to 4th gear and redlines until i slam on the brake and pull over.
Leaking trans fluid from the pan (I just replaced 3 months ago) and is steaming/smoking from the area.
wtf?
Oh man, tough break Tyler. I hope it was just shutting down before it could grenade. Let us know how things turn out. ?
JesseS
Jesse
NorCal (Roseville)
Total Bummer for sure, so the Ranger transmission sure seems to have a lot of issues, makes me rethink my choice.
Let's wait till the OP posts more about the problem....he stated he replaced the pan a few months ago. With what, by who, why....maybe not the trannie's fault at all.....
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
"Going 90...nothing special"
I'd be quite afraid to go that fast in mine. It would be VERY special if I found it necessary to go that fast!
I hope nothing has been severely or permanently damaged. Good luck!
tygr2007
tygr2007
Tyler
Naples, FL
UPDATE!
I think I was just sending er’ too hard and fluid started leaking out of the blow hole. Taking to ford after my mudding trip to see if anything’s wrong.
I think that when they replaced the pan they overfilled it. That’s what one of my buddies said who’s a mechanic.
? Crisis averted… MAYBE? Knock on wood.
Chris M
Surprise, AZ
Security Supervisor
UPDATE!
Again, good luck!
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
UPDATE!
Maybe send a little less hard. These rangers aren't exactly built "Ford tough" no matter what anyone does to em. Or at least get one of them aluminum pans and or better skidplates. Good luck.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
The 10R80 is extremely sensitive from being overfilled.
I had a similar problem coming back from FL with the trailer in tow. I hadn't been monitoring my temps and the trans started flaring between 8 and 9. Pulled up torque and the temp had spiked to almost 250 deg. Slowed down, cooled down and everything went back to normal. Stopped for gas and I'd blown fluid all over the place.
This was pre-fitzstick, so I couldn't check it. When I got home, I checked it and the fluid was still where it should have been, meaning it was overfilled and blew out some of it when it got hot.
It was probably a situation where the fluid was really warm anyways (summertime, towing 6000lbs and running 75 mph) so it started to make contact with spinning internal parts and started foaming, blowing it out the vent.
Ever since, it has been fine.
https://www.sonnax.com/tech_resourc...hooting-ford-10-speed-atf-venting-overheating
" We have found that as little as 1 qt. (1 L) overfilled will cause both overheating and venting on them. "
This is a good point.
tygr2007
tygr2007
Tyler
Naples, FL
Already have all that ?
_TraMor
TraMor
Upstate NY
22 Ranger Tremor, 17 Focus St, 97 Escort Wagon
IT by day, shade tree Mechanic... also by day
I wouldn't call this resolved at all, the same exact things happened to my ranger with the stock pan. The truck is currently at the dealer waiting on either rebuild parts or a new transmission.
I was towed originally to the nearest dealer who reprogrammed the TCM then drove it a few months after. I'd schedule an appointment to get in ASAP, it'll be a long process if something is actually broken.
Good luck.
Dereku
Chicagoland Area
I think we found the issue. Maybe its not the truck, but the driver. Its not a sports car its a truck. Wring them out all day and they fall apart. I know from experience. This is why I will never buy used again.....
