Had a fire in the cabin. All kinds of issues. Help!?!?
Bawest
Brooke
Houston, tx
2019 d ranger
Issue that I came across. as built data doesn't match computer module. Module has line for 737-05 and 06, as built does not contain these numbers.
Also, there are some boxes on forscan that do not give me the option to write but the numbers do not match what is in the as built data.
As built data:
737-01-01 3146 5445 52A2
737-01-02 3445 4834 4B81
737-01-03 4C41 3131 3162
737-01-04 3832 AD
737-02-01 E7E8 EE3B 70A9
737-02-02 3CE6 0100 0065
737-02-03 0000 43
737-03-01 4B91 1E
737-04-01 136A C0
VIN# in Hex Data Format
Hex Lines:
737-01-01 - VIN# 1-5
737-01-02 - VIN# 6-10
737-01-03 - VIN# 11-15
737-01-04- VIN# 16-17
The other hex lines should be the same for all trims
RangerBill
PA
As built data:
737-01-013146544552A2
737-01-02344548344B81
737-01-034C4131313162
737-01-043832AD
737-02-01E7E8EE3B70A9
737-02-023CE601000065
737-02-03000043
737-03-014B911E
737-04-01136AC0
Hex Lines:
The boxes on the extreme right are a checksum calculated by the software and you cannot change them. This is normal.
Bawest
Brooke
Houston, tx
2019 d ranger
Do I need to worry about lines 5 and 6?
I am not 100% certain on this but I think the software version PN may drive what data lines are available to configure.
I know that my 2022 with my module configuration run:
Shows the following:
RCM PN: KB3T-14B321-BD - Software Version: GN15-14C028-CA
All of my As-Built compares do not show 737-05-01 or 737-06-01 in any of the database runs.
If we reference the As-Built Database files (All Fords)
here is what those 2 lines breakdown into:
Being that the Ranger does not use those lines, then if it is listing them I am not 100% if if really matters for those lines.
The most important I guess would be to ensure that they read like this:
0000-xx
so write (zero) 0000 and then write it, it may give a pop up message about check-sum and then write it - the check sum should be auto populated with the correct check-sum for the line.
To point out what the check-sum is:
Its the last (2) hex data of every line, and generally when you write a line (if you leave the last 2 characters alone) they will auto populate the correct (Check-Sum)
Note: this goes for all As-Built Lines such as 1234-ABCD-12xx (xx) = the check sum
I am not sure, I do not remember if Forscan will display the Module SW Number or not, I think it does in the module run.
I know when I played with FDRS last year there were no updates to the software of the RCM.
So I am not 100% but I think the extra lines are due to the module being somewhat universal and another model may require those lines of data and if it follows the rest of the As-Built files then all (0's) on the line equals a non configurable or non optioned line of data.
