Urgent help needed unable to get trans out of park
SBCSD
VictimVille, Ca
2020 XLT Sport
Areospace
This morning I was leaving work and I am unable to shift out of park. I can what I think is a solenoid clicking and the “P” on the instrument panel turn off but I am unable to move the shift lever out of park. Is there a way I can manually release the shift lever? Currently stuck at work trying to figure out what I can do so I can get home.
SBCSD
SBCSD
VictimVille, Ca
2020 XLT Sport
Areospace
Update, just got the shifter to work, at least I can get home now.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
There is a release lever under the shift counsel. The owners manual show how to access it.
It appears, since you were hearing a solenoid click (Brake Pedal - Interlock) releasing.
The shifter cable locking clip (may not be secured) and is allow the cable to flex (stretch)
Just a possibility
SBCSD
SBCSD
VictimVille, Ca
2020 XLT Sport
Areospace
Thank you for the tip. I read the section in the owner manual you were talking about and know what to do if it happens again before I get a chance to check out the the shifter cable locking clip that
airline tech mentioned.
Daren
Daren
Nashville
2019 Ford Ranger XLT
Contractor
Apart from just jiggling the shifter, restarting the engine a dozen times I was able to shift out of park. I have had no issues since. I'll have to look into it further on my day off.
Like everything else in our computer world. Turn it off and back on again.
Rocketeer61
Bill
Utah
2020 Ranger STX
I feel your pain. I once had a GMC Sonoma that wouldn't let me turn the key to start it. Had to have a Tech come from the dealership to unstick it twice. Turns out it was a bad electronic component in the ignition switch. Gone forever are the days when you could just unbolt the slider from the column and start it with a screwdriver.
