Global multi leaf rear spring, anybody know spring design?
Fitzmotor
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
These are the Raptor bump stops, you can also just shorten the stock Ranger stops.
CO2Ranger
Shoran12
Shane
Maryville TN
2022 Ranger STX
Millwright
I don't know how the FX4 springs are, the global ones are pretty soft, softer than the Tremor, if you can drive a Tremor and compare it to your truck, then if the Tremor is a improvement you would know the global spring is little softer, it's too bad you are not closer, it only takes less than a hour total to swap them, I'd give you these to try, if you liked them, I would have you buy a set to replace them, it's only $300 which is dirt cheap for basically brand new factory springs.
A few days ago I noticed there is a shim under the drivers side leaf spring. Did you include this shim when. Installing the global spring?
Fitzmotor
Fitzmotor
Gold Sponsor
Saugus
At first I didn't but I added it back in, as it's to correct the Ranger low on the left problem.
dano42
Dan
California Central Coast
2021Ranger Lariat Tremor, 2024 BMW X5
Retired!
The height change is only about 1/2 inch, no alignment needed.
I was hoping someone knew the performance differences between a spring with long thinner leafs and a spring with short thicker leafs, I know Jeff at Deavers has insight into this, he made a custom 1.5 drop pack for my Raptor, he's just so busy I hate to bug him and he is also one of those people who look at me like I'm crazy for wanting to lower the back of a 4x4 truck.
I put 2” drop shackles on my ‘20 FX4 SCREW and it seemed to drive a little better-weight distribution shift? Looked better too.
Fitzmotor
Fitzmotor
Gold Sponsor
Saugus
I have leveled almost every 4x4 I have owned, I dont care for any rake, but now that I'm old I do to help me load my bike!:crackup:
Where did you find "drop" shackles for a 5G ranger.
Fitzmotor
Fitzmotor
Gold Sponsor
Saugus
That has to be a F series, no such thing exists for a Ranger.
I didn't think so. Not enough space between the spring and frame for that much drop.
Superspirit
earth
22 ranger
Got mine this evening also. Do the original bushings fit the rear or do I need to source new bushings? There is 1/2 a bushing in one spring and none in the other.
Sib6019
Forrest
2021 Ranger Lariat
Account Manager
I believe our exist bushings will work, one of my spring's bushings are completely missing. My packaging was trashed, so I suspect they fell out. I may look into seeing what options (different materials) are out there to replace them.
