GFB DV+
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I figure anything besides the stock snap open/slam shut is going to do something.
Mustang2Ranger
Garrett
Southern California
It says somewhere in the instructions or a video to clean and oil it every 10-15k with a few drops of regular motor oil
kieefer
keith
I noticed my balkingness and flat spot throttle response was back so I checked on the GFB DV and the brass piston was stuck. Kinda got crooked and wedged in one spot.
Maybe because I left the spring out but anyway I’m done with it.
If anyone wants to try one I’m putting this one up FS.
Doc
Doc
Live oak fla
Go Fast Bits….:)
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
So I see this is only $125 at AMAZON
May give it a try.
I just read thru all 19 pages; screw threads, IP and AliExpress... oh my!
I wont get into where to buy that's up to the buyer.
But, from an engineering stand point changing self tapping plastic screws to machine screws is not ideal. If the machine screw is smaller it will "work" but as one user commented stripping would be a major concern. Long term plastic cracking or screws loosening could be an issue. But users have also commented on having these installed for years, so maybe low risk.
IMHO the mfg cheaped out by not sourcing a matching longer plastic screw rather that a machine screw. An OEM would NEVER use a machine screw in plastic.
Well like I said I am interested and have not bought anything for my Ranger in a while! ?
Racket
Here and There
Transient
Wonder if it's a knockoff. OEM is self-tapping into plastic. Those of us that upgraded to aftermarket intercooler charge pipes use threaded now.
EDIT TO ADD: I wonder if leaving the spring out contributed to the jam?
DMVRanger
Tyler
2020 Ranger XL 2WD
Server
Soooo is it louder than a turbo smart?
Danny15l
Dan
Duvall
2020 ford ranger XLT sport package 4x4
Just installed mine! Haven’t driven it on the road yet. I like how much more heavy duty the GFB internals are compared to the stock valve. Wonder how it will perform under boost conditions now that it’s partially close/opening. I just chipped the plastic piece that’s needs to be taken off of the top part solenoid. If I return to stock I’d probably buy the upgraded aftermarket DV from turbosmart.
Danny15l
Dan
Duvall
Contacted GFB also and asked about maintenance of the brass piston with cleaning/re-oil and they said:
“There is no need to periodically maintain your valve, it has been designed as a maintenance free part. Although, there is no harm in visually checking any automotive component periodically for peace of mind, especially if the car is an offroad vehicle.”
I think I’ll check mine after 20k. Can’t really use the sport package off road..
Sariandan
Kevin
The lowcountry of SC/GA
2022 Ford Mustang EcoBoost
Paramedic/Shift Supervisor
Since this thread is a sticky, I figured I'd post this in here. Someone may find it useful. Or, maybe it's already a known thing and I'm slow to figure things out.
A week or so ago, I upgraded my charge pipes. During the swap, the longer screws for my DV+ went to be with the 10mm sockets, never to be seen again. The screws that came with the new charge pipes were sized for the factory diverter.
I temporarily used the TurboSmart dual port that I have, since it would bolt on with the shorter screws. In the meantime, I contacted GFB and found out the screws they send are 35mm long. The screws needed for the aFe charge pipes are M6x1. So, went to Home Depot and got M6x1x35's and they worked great.
I remember reading that some people did not like the screws GFB sends. So, if anyone is getting one and is looking for different screws... M6x1x35, from Home Depot.
Racket
Here and There
Transient
Jsmitty0024
Justin
2023 Ranger Lariat Tremor
Environmental consultant
What about the steeda part?? The VTA
OGMix376
Bryan
Looking under Ranger this is all that is showing. So it seems this is all one piece and does not use stock parts.
https://www.pandamotorworks.com/products/gfb-diverter-valve-dv-2024-ranger-raptor-3-0l
They improved on the original GFB BOV, made it a drop in solution opposed to one that would (I believe, could be wrong.) need you to modify the original electronic solenoid (removing the original plastic valve assembly and replacing it with the metal more robust GFB base.)..
this one (the one you posted) is a drop in replacement, much nicer in my opinion and has a very low profile design that I think is pretty cool.
21rangerCactus
Self employed
Well I thought about getting it but I just bought the previous model off a member here for $65 shipped.
