Gap when Tailgate is Closed
Which seal did you use ? Install details ?
I used the extang seal and followed their instructions. I didn't need to do the bottom since I have a BedRug. One thing I found - don't forget to seal at the top of the tailgate - the little piece along the plastic cap. If you just seal the bed, it will cut down a lot, but that hole at the top allows a lot of dust in.
Edit: Here is a picture of the spot I'm talking about - this is from an install guide for a different seal, but you get the idea - I did it slightly differently, but if you don't make sure that is covered it is a big hole.
Stevo56
Duluth, MN
2020 Ford Ranger XLT, 2023 Ford Edge SEL AWD, 2012 Ford Mustang
DocE3Gun
Dillen
Missouri
2020 Ranger Lariat Fx4
self employed
I ordered this from Amazon:
https://www.amazon.com/ESI-Ultimate-Tailgate-Taper-Ranger/dp/B07YF5BL8M/ref=sr_1_8?crid=2EJ5KRXU2QJI8&dchild=1&keywords=esi+tailgate+seal&qid=1603549271&sprefix=Esi+t,aps,202&sr=8-8
Unfortunately, it has been too cold here in Siberian Minnesota to install. If it warms up I'll give it a try.
Edit: detailed install instructions.
https://tailgateseal.com/FordRanger2019.html
I installed this exact kit a week or two ago. After driving over a dusty range in Texas, gravel roads in North Carolina, and gravel roads in Missouri....I'm very happy with how well it keeps dust out!
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Thanks! I might have to give this one a shot. I don't know how I hadn't found it yet.
Good to know it's working for you! If it's actually installed by someone else and works for dust, that's a huge selling point for me!
DocE3Gun
Dillen
Missouri
self employed
I installed mine myself ..... it was less than a 2 beer project
Stevo56
Duluth, MN
Sounds good. I will be warming up the garage and installing this week.
quirkybar8
Indy
2019 Ford Ranger 2WD XLT
Having already tried Extang Maxseal, according to https://tailgateseal.com/ you didn't miss it. Looking at the install process specific to the Ranger, you have to stick a bunch of short pieces on to close up the enormous gaps. Pretty hokey. Maybe the tailgate is on the list of changes for 6g.
edit: it's a kit specific to the Ranger, so I'll let Emily Litella respond for me.
Stevo56
Duluth, MN
It finally got warm enough to install the seal. Easy enough to do. Now to see if it works. On a side note, whoever designed the tailgate probably should have consulted with the box designer. Having to patch in bits and pieces of weather seal into different places is ridiculous.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Agreeeeed. This was a massive fail on Ford's part.
Keep me posted on how that seal goes, at this point I'm leaning towards that than hacking up my own solution if it works.
Stevo56
Duluth, MN
I am going to run it through the car wash tomorrow. I'll report back the results.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Lets hope that as the Ranger population grows someone will invest to make 1 piece molded solution
