FX4 Off Road Angles Display
Toytec
Central NC
I would say you have a few inclines in your area to give it a test.
This information is put on the screen by the Yaw rate sensor I would imagine.
FULLSCALE
Adam
Ontario, Canada
I didn't realise it showed the steering angle too. I like it!
Jimiv123
Dallas, TX
2019 Ford Ranger Lariat, 501A, FX4, Sport Package, Magnetic
IT Grunt
So from left to right it's Pitch, "Yaw" and Roll?
rangerdanger
rangerdanger
SF Bay Area
Hirnlego
SC
2019 Ford Ranger XLT 302A
I was researching what this code actually does.
In a non FX4 models it displays the PITCH, STEERING ANGLE, and YAW/ROLL? Are these all accurate readings without FX4 or 4X4? No electronic sensors needed?
This FORScan code is separate from the Trail Control (cruise control for off road) on Trail Management (Button in 4X4 control near the gear shifter)
Deleted member 1634
I always forget to pull this screen up when I'm doing, what I perceive to be, crazy off camber maneuvers. And when I finally remember to pull it up to see just how crazy it was, I'm already past all the crazy stuff. haha
Rviator
FLA
retired aerospace engineer
The OP's picture is displaying pitch, steering angle, and roll in that order. Yaw is not displayed as it's irrelevant.
t4thfavor
Chance
Yes, it needs all those signals for the other safety features to work properly, so there is no new hardware in the FX4 or 4x4 for those data points.
Jon Olivier
Jon
Bishop, CA
It's under "Truck Information" (or some name like that) on the dash main menu screen. Just keep paging down past Trip 1 and Trip 2 and all that.
The center image (steering angle) also shows when the front diff is engaged. You'll see the front drivetrain graphic lit up.
Deleted member 1634
Interesting. I'll have to try and remember to check this menu page out more often. Now to just escape winter intact so I can get back to some off-roading and actually have a reason to use this menu page. haha
CO2Ranger
Shows a lock symbol on rear diff when locked too IIRC ?
