Fuel in oil
Floyd
illinois
This is most likely my final oil analysis before my warranty expires. According to the Blackstone report, my oil dilution issue is at 2.3%, which is the best it has tested since my second oil change at 12k miles. The other good news is the oil analysis isn't showing signs of wear as evidence of the lack of elements in the oil.
Just to be safe, I will be purchasing an extended warranty before I reach 60k miles.
if you need that warranty its FAR more likely to be some of those cheap elsctronics that they are so fond of overcharging for!
BTW; if your Battery is original... do the reset now , before the truck decides to ruin it.
JustSteve
2019 Ranger XLT
Please explain
What does that mean? Reset what and how does the truck ruin it?
ccasanova22
Lakeland, MN
2022 Ranger XLT Tremor
I think he is referring to something about the BMS or charge state. Which may ruin the battery over time.
I think I am the only Ranger on here that consistently uses oil. But mine is a 100% highway truck, state to state driving, with 400 mile trips the norm and no city driving.
My Blackstone noted a little fuel dilution but they said “it’s nothing to worry about” so I believe it’s 100% normal.
Floyd
illinois
The computer keeps track of the install date and reduces the charge rate over time.
This must be reset when a new battery is installed.
Ostensibly, it is to preserve battery life by not overcharging as the battery ages.
Unfortunately this can become inadequate for short trips after a few years.
I replaced my battery at just over 3 years, only to learn of this issue afterward.
I then recharged the battery on the bench and it tests good and holds a charge well.
This is by far the shortest "battery life" on any new personal vehicle I have ever experienced.
I would do the reset procedure before I resorted to replacement, just to see if the low battery issue mitigates... If not be sure and do the reset on the new battery or the truck will "think" its still the old one.
In my case, I believe my batteries failed...the last few days, I needed to jump start...last night I manually charged it to 100% but was again dead in the morning...it's lasted 110K miles so perhaps it's served it's purpose...
In another thread, I'm still trying to confirm weather 48 and 94 size are interchangeable? Autozone shows that a 94 is compatible with XLT...is this true?
jsphlynch
2019 Ford Ranger XL
How do I do the reset?
When I was trying to figure this out for my XL, I had seen somewhere that the 94 is sort of compatible...to get it to physically fit there was a part that needed switched out; I don't recall exactly what but I think it may have been the battery tray?
Floyd
illinois
I replaced my smaller battery on my STX with the larger battery which is supplied with the XLT& Lariat. I chscked for compatibility and price with my Ford dealer. Turns out the Motorcraft Battery at my dealer was cheaper than my local AutoZone for an equivalent.
Dealer confirmed compatibility. the only thing was the battery blanket was a bit small, but the battery fit in the tray just fine.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Just wanted to show you Kubota standards allow high levels of fuel in the oil and say its normal for their Sidekicks. Here's 2 analysis reports from my oil that are within their limits at concernable levels
SyberOrange
Val
Lebanon, TN
Locomotive Engineer
I installed the UPR catch can about a week ago, and after about a 600 Mile road trip this last weekend I wanted to see what it had captured, and much to my surprise it contained a few ounces of gasoline (maybe a little water, but it has been warm here in Texas and the engine never cooled down during the trip). So I then figured I should check my oil, and sure enough it reeked of gasoline. Then I went back and checked the level, and it was way overfilled! Obviously a ton of fuel in the oil. Only 1800 miles on the truck, almost entirely highway. I only take it for drives into town (about a 20 mile drive one way) and roadtrips. We have 2 beaters we drive to work each day. I took it to the dealer yesterday and no word back yet. How much extra wear do you think that could've caused the engine in that amount of time? Should I press Ford for an extended warranty on my engine? If I was like many owners and just followed the 10,000 mile oil interval without ever checking who knows how bad it could have gotten. I also wonder what caused it. My best guess would be a leaking injector, but maybe a poorly seated piston ring? I'll report back here once I get it back from the dealer.
Many are out there (Including myself) with the Fuel Dilution issue.
Hello everyone with fuel dilution of critical level (>2.0%) contact me ASAP to join our efforts to file a claim to defend our customer rights. We need at least a group of five.
SyberOrange
Val
Lebanon, TN
Locomotive Engineer
Just took my Ranger in for excessive amount of fuel in the oil. They changed the oil marked the stick and are going to have me bring it back in 500 miles. They seem to think after conferring with Ford that it's in the PVC system. Will post follow up after the 500 mile check!
I went through the same. All that and another FSA inspection.., and In the end, I was thrown under a bus. There will be no word on "Fuel Dilution". They call it "Oil Consumption" test which is not the same and does not fall into the category of the issues we've been having with our Rangers with 2.3L EcoBoost engines. We need to unite here folks. Contact me ASAP to join our efforts to file a claim to defend our customer rights. We need at least a group of five.
Joeiconic
