Front fenders
stringbreaker
washington state
2019 Ranger XLT
What material are the front fenders made from? Doesn't seem to be aluminum or steel. Feel like some kind of plastic similar to what the front fascia is made from. The doors sound like metal when you tap on them with a knuckle. Hood is supposed to be aluminum correct?
The front fenders and hood are aluminum as well as the tailgate.
OxyGenIII
Corey
Minnesota
Are the doors and rear fenders steel then? Ive been curious as well. Would love for more aluminum to prevent the dreaded rust down the road but probably a cost saving measure
DHare
Missouri
Are the doors and rear fenders steep then? Ive been curious as well. Would love for more aluminum to prevent the dreaded rust down the road but probably a cost saving measure
A magnet will give you a quick answer to what is steel and what isn't.
stringbreaker
stringbreaker
washington state
2019 Ranger XLT
Did the magnet test and as I thought the front fenders are definitely not metal, neither aluminum or steel. I worked in the metal trades as a tool and die maker all my life and I can pretty much tell if something is metal or plastic. Those fenders are plastic. Might be a good question for Phil.
Hi Mike,
The hood, front fenders and the tailgate are aluminum. Rest of the body is steel. I adjusted my left front fender to better align with the hood...clearly shows the unpainted post adjustment unpainted semi circle shows metal...
Glocker
Boca Raton
The front fenders are indeed aluminum. And cutting a huge hole in your nice aluminum Ranger fender kinda makes your anatomy shrink into your body. :D
ControlNode
Eastern NC
Computers
Well, at some point they clearly switched to steel fenders. My Oct 2021 built Ranger has steel. Now I kind of what to see if I can find aluminum fenders painted Cyber Orange from factory.
Dereku
Chicagoland Area
Well that was probably to make up for all the weight lost lost from removing features.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Unless you're going for rust-prevention or whatever, you won't find any positives switching back to aluminum. Trust me, the steel is paper thin.
Only advantage is weight, but I'd be curious to know how much lighter the aluminum fenders are. I can't imagine it is that much weight savings.
I'm pretty sure they changed to steel due to availability constraints. Gotta keep the F-150s all aluminum you know! ?
RedDakooter05
Illinois
Well not sure of the exact figures, but my Crew cab ranger weighs the same as my aluminum bodied F150 XL Reg cab did if we ignore the couple hundred pound difference. My F150s body panels were actually thicker than these steel bodied rangers.
I'm surprised they kept the tailgate and hood aluminum tbh.
JeffWoodall
2021 Ranger STX 4X4
Security, Retired military (20 yrs), retired law enforcement (15 yrs)
Is this legit? I found this while searching for TSBs. I may have missed this, haven't been on in a while. I have a 2021, but the fenders are definitely aluminum.
RECORD_ID: 3488599
Bulletin Number: SSM 50793
Replacement Service Bulletin Number: N/A
NHTSA Item Number: 10212124
Date Posted: 05-20-2022
Component Name: 160000 STRUCTURE
Make: FORD
Model: RANGER
Year: 2021
Date Added: 05-24-2022
Summary: The 2021 Ranger front fender material migrated on 22-Apr-2021 from aluminum to steel. Additionally, service replacement fenders for 2019-2022 made of aluminum are no longer available. When replacing a front fender on Rangers built on or aft
Living The Dream
This is legit.
I believe it's about the same timeframe as when the spindles also went from aluminum to steel.
Edit: @Trigganometry pointed out that the spindle change actually occurred about a year earlier.
