bbeverag
- First Name
- Bob
- Joined
- Jul 31, 2023
- Threads
- 4
- Messages
- 112
- Reaction score
- 324
- Location
- Normal, IL
- Vehicle(s)
- 2022 Ranger Lariat Tremor
the opposite on this particular item.2. Fuel economy should jump up
Nope. Mine went up.the opposite on this particular item.
I would guess that the gears would still be warranted through the manufacturer and the shop will warranty their labor. I've done this many times with parts (did it with my Eibach on my '19 Ranger) and never had any problems. Plus you don't have to worry about the shop adding $$ onto the price of the parts.Have them order the gears for warranty purposes.Dont give them an out.
I'm starting on bolting up my beadlocks with the 37s tonight then alignment on Friday. So, gears would be quite nice to have.I have done a bunch of calculating and shopping with local shops to find an installer. I've settled on 4.46 because the shop that will install them is $600 cheaper than the shop that will install the 4.88. I also am only going to 35s, so I don't need the extra pep.
You are unique then, if a manufacturer could increase their fuel economy with a regear that felt good for performance, they would. As it is, they go with higher ratios which make the vehicle feel slower so they can squeeze more economy for their CAFE standards.Nope. Mine went up.
Then you don't understand ratios and larger tires. When you put bigger tires it moves the power band. You've moved the normal operating range below the intended threshold. It struggles more at rpm's that are too low. Change the gears and it puts you back into a more efficient range. That's the math. The only other person I know that's actually done the gears said his mileage went up significantly.You are unique then, if a manufacturer could increase their fuel economy with a regear that felt good for performance, they would. As it is, they go with higher ratios which make the vehicle feel slower so they can squeeze more economy for their CAFE standards.
Aside from being done? It's running exactly as I expected it to. Rpm's are in the right range, no more lugging in 10th, no more needing to downshift as low as 46mph. And tons more acceleration of the line.
Considering my driving patterns since I've done the gears have been worse and I'm still getting about the same and better is working. Stock was around 1900 at 55 mph. That's what I'm back to with the 33's. I would try to shoot for that speed/ rpm range with whatever tires size you have.Have you had a chance to calculate your fuel economy? I am stuck in decision anxiety about 4.46 and 4.88. The calculators seem so close, but I don't want to make the wrong decision.
I'll note again that the Dana engineer i spoke to said that only up to 4.46 would fit the stock housing. It's about the ring gear distance to the housing. Anything closer to the housing and you'll have oiling issues. I would look into that.
