Free Sync 3 Navigation Map Updates (NA 1 18)
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
chasvs
Tampa
Too weird and very frustrating! So, I finally get to the point where it says the System has been updated, I can remove the USB Stick and updates will be applied when I restart the Truck. OK, restart and get a couple Update notifications but when I check the Map Version it’s still NA 17. Wtf? When I start the truck with the USB Stick now, nothing happens!
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
did you give it like 2 or 3 minutes before restarting?
chasvs
Tampa
Yeah, like 1/2 an hour.
Thought I’d try to redownload and try again but now in the download link my only option is to buy the Stick!
VAMike
2019 Ranger Lariat SuperCab
Use the link from the email to download again
Figarou
The exact same thing happened to me. Did everything the instructions said.
The Gracenote seems to be updated. I didn't see a version # before the update. Now it says 1.1.1.1332 (NA-0010) after the update.
UofMEngineer
That's a known glitch with the update on v3.3. It's actually 18Q1 after the update, but that version string doesn't change. You can double check the package versions in the diag menu and compare them against the ones on the update stick to confirm.
Hi UofM,
Okay...known glitch...is it going to be fixed?
chasvs
Tampa
Yeah, that’s what I got as a result of the update. Grace note has version info now and Navigation is still NA17
UofMEngineer
Hi UofM,
Yep. It's fixed in v3.4. I forget what the problem was in v3.3 with the version info being wrong / not updated. I heard about it when I was testing the map update update back before it went live.
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Fixed in 3.4 you say? Is that why my version number updated properly? :bandit:
chasvs
Tampa
So, is the glitch that it doesn’t show the correct version number, but we actually do have the update installed?
UofMEngineer
Yeah, if you're running v3.4 it should show 18Q1 correctly.
That's correct. It doesn't look like it's updated based solely on the About screen info, but the actual map and voice data have been updated.
You got 3.4 to install? If so, you have to spill the beans....
I did the map update today and same as others it completed successfully, the Grace Notes now shows a version, but the maps still show 1 17.
Sarge104
Perry
Montana
www.facebook.com
19 FR, 13 VB, 95 GS MH, 00 HE
County Cemetery District, SAR volunteer
Been very frustrating but last night went out and took a drive to get the updates done. What a PITA! Over six hours spent getting this done and now I get to figure out how to update the SYNC3 again? Why cant that be done OTA? I checked twice before doing the map update but it didn't say anything about a SYNC update.
