FORScan Modifications
JesseS
Jesse
NorCal (Roseville)
Scusa ancora non ho fatto pratica ciò sito e non mi sono accorto della data
Va bene, non sono sicuro che riceverai una risposta pubblicando in italiano
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Ford ASSET Instructor - Program Director
I have 2.3.48 - I need to try that version - Thanks Loren
Here's the million dollar question - why wouldn't the current release have all the features of a previous version?
Just confirmed, 2.3.48 does not have the GUI for PCM changes on mine either - also running paid version.
micl9
Apex, NC
Thats where it gets tricky
Could be they just had a regression issue
OR they found an issue on .47 and took it out of .48
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Also, .47 doesn't exist on the FORScan site anymore. When you go to version history, the link for .47 takes you to .46. I grabbed the .47 file by changing the file location name - it did download - installed .47 and sadly, still no GUI/Easy Mode for the PCM.
I have the Ford Performance Tune if that matters.
micl9
Apex, NC
Did you try creating a new set up (or what ever its called) file? The one that loads at the start.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
A new profile.
99% of the time, with a paid license this is all you need to do.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Aha, I did not do that. Thanks for the info @Gizmokid2005
I will have to flash the PCM to stock first and then create a new profile unless that issue has been fixed. I was not able to create a profile with the tune in the PCM. Once the tune was removed, I was able to create a profile and then re-flash the tune back in.
I just paid for a full version a couple weeks or so ago so I have been using the old profile.
micl9
Apex, NC
Ok just loaded .47 and did a new profile - no joy
Tried both the "canned" profile and the start from scratch. Also tried both 2019 and 2020.
daczone
2020 Ranger
If anyone is still using a adapter with a HS/MS switch you should really get the approved adapter ($59 on Amazon), and it is so much nicer to not have to switch it back and forth as you work your way through any of these mods with Forscan.
Porpoise Hork
Bret
Houston
IT
Saw this over on the F150 forums. This was one of the most irritating things the ranger would do in winter time, flippimg to fresh air every 10 min... Maybe it will work for you guys. I just did it on my F150 but it'll be months before I can test it.
If you want to give disabling it a try:
HVAC
733-01-07 xxxx x8xx xx (If OEM is A)
If you have a OEM as-built other than A, reference the spread sheet to find the correct value.
SSM 50015 - 2020-2021 Various Vehicles - Enhanced Windshield Anti Fogging Strategy (EWAFS)
Some 2020-2021 Ford and Lincoln vehicles are equipped with an anti-fogging feature known as enhanced windshield anti fogging strategy (EWAFS). This feature automatically adjusts airflow in the cabin to prevent the windshield from fogging up and may be perceived by customers as irregular climate control functionality. To reduce fogging, the EWAFS functions include: the air condition (A/C) button may turn on and off automatically, recirculated air may turn off automatically in all air modes except MAX A/C, recirculated air may also turn on and off automatically in various airflow modes in order to improve heating or cooling efficiency, and in auto climate control, high humidity conditions may automatically engage A/C compressor, increase blower motor speed and/or direct more air to windshield. Continue to monitor the Workshop Manual (WSM) for EWAFS updates.
https://www.f150gen14.com/forum/thr...an-list-database-spreadsheet.1578/post-154137
RAYJAY
UNION DALE PA
ONE QUESTION .....have a tune on truck do i revert it back to stock before i use for-scan ????
Langwilliams
Langley
Lorain, Ohio
Revert back before taking it into the dealer for any service. If they do an update with the aftermarket tune your base tune will be out of date
P-38Ranger
San Diego
2022 Ranger Lariat
Well, the days are getting shorter, so I am driving in the dark. For the first time I notice that my high beams will come on by themselves, and slower that 30! I'll check other threads, but this is the first thread that showed me it wasn't a mechanical short circuit!
