Ambient light for what? I find that all the gauges, dash, and sync screen are nutso at night and often find myself turning them down.Is there a way to increase the ambient light output? Even on high setting, it is very dim
Sorry, in Lariat there is a setting for Ambient lighting which is small LEDs by your feet and door handles.Ambient light for what? I find that all the gauges, dash, and sync screen are nutso at night and often find myself turning them down.
each color has a slider for brightness, i have mine all the way up, i wouldn't want it much, if any brighter than that.Sorry, in Lariat there is a setting for Ambient lighting which is small LEDs by your feet and door handles.
I've turned the slider all the way up and it's super dim to the point of being useless.each color has a slider for brightness, i have mine all the way up, i wouldn't want it much, if any brighter than that.
I recall that being addressed a long while back. Also recalling no one found a way to get them any brighter.I've turned the slider all the way up and it's super dim to the point of being useless.
Not on US Rangers. We don't have door modules. Need to buy a after market module for this to work. A couple threads on it. Do a search.Yes, it should be in the manual under windows and mirrors. If its like mine, you just unlock the unit then hold the unlock until the windows move. I also had to enable this feature in the settings menu in the cluster. (someone with a US ranger can confirm)
I think I figured out what the problem is but I do not know the solution.Not sure if I should post this here or in Lighting.
Interesting issue with my recently installed switchback turns.
Iāve noticed that they run Amber as DRLās (having the switch on AUTO). They will turn White once the headlights come on and stay on.
If I manually set the switch to parking lights they are White.
If I manually set the switch to headlights they are white.
Seems like leaving the switch on Auto causes them to run Amber until the headlights come on - weird.
Now, I did make the change (Forscan) awhile back where my Parking lights are my DRLās.....and when I did that only the Front lights are used for DRLās....not my side markers or tail lights.
any ideaās as to why the switchbacks act this way?
i dont know about you but i like having the sidemarker and tail lights on when with drls, cant be too safe with the idiots here in upstate NYI think I figured out what the problem is but I do not know the solution.
When I used Forscan to change my DRLās I made the following change that I believe uses my TURN signals for DRLās as I did not want my side markers or rear tail lights on when in DRL mode
BdyCm
726-45-01 xxxx 7Fxx xxxx and
726-50-01 0886
This causes my switchbacks to run Amber in the AUTO setting as they are in the turn signal mode (not flashing as they are DRL at this point - they do work correctly when I have my switch on parking or headlight mode).
What I am after is to have the switchbacks be white with no other lights on for DRL in the Auto mode.
Can anyone offer advice as to if this is possible in Forscan or will I have to enable Parking Lights only for DRLās and then be forced to have to side markers and rear tail lights on as well.
Appreciate any assistance for you folks with the Forscan knowledge.
Thanks.
Sorry to keep adding on here but Iāve been playing with this for awhile now.I think I figured out what the problem is but I do not know the solution.
BdyCm
726-50-01 0886
Thanks.
Hooray!!!! I figured out how to do it - run parking lamps only as DRLās. No headlights or fogs.Ok. Letās wrap this up.
Bottom line is there appears to be no way to do what I want as the option to do that is using Turn Lamps and not Parking Lamps. Thatās why my switchbacks were amber.
I reset BdyCM and started over. I now have parking lights as DRLās and my fogs. The switchbacks now work as they should. I did not want my headlights on thats why I used the fogs instead. I guess Iāll have to live with the fogs - issue with having those included as DRLās is that they are the superbright white/yellow and toggle between the colors with each on/off meaning sometimes my DRL fogs will be white, sometimes yellow and I probably wonāt know which they are.
Until someone with coding knowledge might be able to dig into this, itās the way itās gonna be.
