FORScan Crowdsourced Wiki
thndr8
Rod
CO
Ranger
2021 Lariat. I've accomplished almost everything I wanted except 2. Mostly a novice with this program so I stay away from going into the "as built" stuff. 1: Navigation in motion, I want this turned off and can't figure how to do it. 2: Climate control on the right side of the instrument panel, when I turn it on, it comes up but will not change my climate settings. It reverts back to the original settings set through the HVAC panel or SYNC screen. Any tips?
Bigcb001
Charles
2021 Ford Ranger XLT 4x4
I have been unable to locate the IPC Module in forscan connected to my 2021 Ford Ranger. Any help please?
Bigcb001
Charles
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Make sure that you are using a new profile and that FORScan is up to date.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Anyone know where the setting is in Forscan to keep the 12V outlets inside the cab on all the time? I like to keep my phone in there charging and it sucks that it powers off after a while.
I did this one and it didn't work: 726-39-01 setting XXXX X1XX XXXX, changed 1 to 0
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
There isn't a way to keep them always hot, even with FORscan.
Muffin1
NJ
2019 Silver STX 4X4 SC
Has anyone over the last two weeks been able to use the free version? I have not been able to get an ‘activation’ code but did get the 60 day license key, confused .?
TIA.
Justin says...
Justin
NC
2024 Maverick XLT Lux
IT System Analyst II
Is it possible to enable transmission temperature or oil temperature? Anybody tried these?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
No, we don't have an oil temp sensor to read from, and you can get transmission temperature from OBDII but not in the dash anywhere.
Freezie
Saskatchewan
2022 Ranger lariat
Refrigeration mechanic
Has anyone ever figured out a way to keep the transmission gear numbers up in the display permanently?
Sevenznuf
Shane
2021 ford ranger sport 4wd
Furniture
What does the instantaneous fuel economy gauge do?
