RCMUSTANG
- First Name
- Ray
- Joined
- Jan 22, 2019
- Threads
- 22
- Messages
- 1,867
- Reaction score
- 2,192
- Location
- Los Angeles
- Vehicle(s)
- 2017 Fusion 1995 Ranger
Did the speed limit sign not get added to the main list?
It's listed under "Navigation in Motion" in the list.Did the speed limit sign not get added to the main list?
What is steering wheel switch packs?Steering wheel switch packs:
SCCM:
Left switch 724-02-01 xxXx.xxxx.xxxx -- 1 = Std cruise, 2 = ACC
Right switch 724-02-01 xxxX.xxx.xxxx -- 0 = Lariat media, 1 = Std audio
These are in the configuration menus for the SCCM using the switch part numbers as well as a couple of other options.Steering wheel switch packs:
SCCM:
Yes.Couple question regarding ForScan... I did a quick search but didn't find anything.
1) can you save a setting before you change it?
2) can it be reset so that Ford doesn't know we are changing settings?
3) is there a way to back up the setting you have changed (ie im taking the truck in for service and I have 10 settings I have changed can I save these as one event or do I have to make 10 changes once the truck is done and Im back home?
Why Ford thought it a great idea to turn the damn radio off after 15 minutes annoys the piss out of me...I understand this can be fixed in ForScan... this is enough of a reason to get this...
When I took my 2020 in for an oil change, nothing was said about the Raptor screen, and they didn't reset any of my other changes...Couple question regarding ForScan... I did a quick search but didn't find anything.
Why Ford thought it's a great idea to turn the damn radio off after 15 minutes annoys the piss out of me...I understand this can be fixed in ForScan... this is enough of a reason to get this...
WOW that was fast Thank you Sir! Ordering my adapter today.. Awesome Thank you!Yes.
Yes.
Yes.
You can go into the "ASBUILT" modules, which will let you save the full hex to a file you can save on your computer. You can also load from these files at any time.
The only downside I've found so far is that you can't do this from the GUI options pages, only the ASBUILT hex pages. (But note, that regardless of where you change the settings, using the GUI options or HEX, they will always be reflected in the HEX pages you save/load.)
YESokay last question for now I assume I want an extended license?
I opted for a 1 year license. I could've likely gotten away with two 30-day licenses from them, but the $10 for the year is way worth it to support what they're doing and give me time to tinker at my own pace.okay last question for now I assume I want an extended license?
Agreed - I tend to support those who bring value to the table, and Forscan has given me way more value than the cost of a license. I encourage others who have benefited from this work to do the same.I opted for a 1 year license. I could've likely gotten away with two 30-day licenses from them, but the $10 for the year is way worth it to support what they're doing and give me time to tinker at my own pace.
I bought the lifetime....if it fixes a couple things that annoy me it's worth it!Agreed - I tend to support those who bring value to the table, and Forscan has given me way more value than the cost of a license. I encourage others who have benefited from this work to do the same.![]()
It is called “Seat Button Icon” adds heat control buttons to HOME/Climate Controls on head unit displayIs there a GUI for adding heated seats icon to the Home screen or secondary menu?
